Install Forward Controls
Old Nov 7, 2010 | 12:57 PM
hig4s's Avatar
hig4s
I just installed my forwards, just removed the front muffler..
How hard depends on the quality of the kit,, I got an aftermarket chrome kit with ISO pegs, and the machining was not the best It made it real hard to get the pegs and peg springs mounted on the clevis, I actually used the clevis from the right side stock mids, and one of the stock peg springs, and one of the stock peg hinge pins to get it to work.
Old Nov 7, 2010 | 07:15 PM
Night's Avatar
Night
6th Gear
I put forwards on my '08 Nightster. Only issue I had was extra build up of powdercoat in the front mounting holes. I had to re-tap the holes. All I did was remove the exhaust slip ons not the header parts. Used a "T" handle allen wrench on the bolts.
Most important tools - a good friend, a couple of beers and patience.
Old Nov 7, 2010 | 07:20 PM
exemexer's Avatar
exemexer
Originally Posted by TheLastOiScout
Just got a set of forward controls for my Iron, on a scale from 1 to 10(1 being filling the gas tank and 10 being total engine rebuild) how hard is it to install. And do I need anything else other then what comes in the package. Thanks.
Just curious, where'd you get them and how much?
Old Nov 7, 2010 | 08:00 PM
hig4s's Avatar
hig4s
I got mine from Forward Power Sports on Ebay http://myworld.ebay.com/ebaymotors/forwardpowersports/ for $239.
Old Nov 8, 2010 | 07:29 AM
thatguy021's Avatar
thatguy021
whatever you do don have harley do it. they charged me 300 bucks for labor if i remember right.
Old Nov 9, 2010 | 02:02 AM
harvema's Avatar
harvema
Im looking at getting same controls from the same people... was a bit concerned with the quality, how do they look?
Old Nov 9, 2010 | 01:12 PM
hig4s's Avatar
hig4s
They look pretty good, the machining is not the best, one of my clevis' was mis drilled, but they overnighted me another. The hinge pins just barely fit because of the chroming,, you may need to touch the edges of the hinge pin head with a grinder and the stupid little flat springs for the pegs are not quite right, I just used the hinge pins and springs from my mids.
crashlann
Feb 21, 2020 07:36 AM
LozoB
Aug 29, 2010 11:09 AM
BUZZBEER
Jul 1, 2009 06:41 PM
Shinysideup
Apr 13, 2009 10:24 PM
DEREK71
Dec 9, 2007 06:46 PM
