Leaking primary fluid...
Old Nov 21, 2010 | 04:26 PM
WRAITH's Avatar
WRAITH
The only spot under the inspection cover, that could leak is the shifter shaft seal. Easy DIY.
Old Nov 21, 2010 | 04:30 PM
HD&CUMMINS's Avatar
HD&CUMMINS
Not the shifter shaft seal. Its coming from inspection cover, lower portion of it.
Old Nov 21, 2010 | 04:54 PM
dyna105's Avatar
dyna105
If you had pre lubed the new gasket, could it just be some excessive oil running off? May want to just clean mating area and try again. If new oil showed up than replace again. Just a thought.
Old Nov 21, 2010 | 07:05 PM
themac5150's Avatar
themac5150
Be very careful on the torque of those screws. My owners manual and service manual both call for 84-120 INCH POUNDS of torque. More than one thread was brought up on XLF before when the recommended torque was used and the bosses shattered that were threaded for the fasteners.
http://xlforum.net/vbportal/forums/s...+primary+cover
AGAF
Oct 24, 2016 09:10 AM
Timmy B
Apr 1, 2013 10:06 AM
malibu1979
11
Apr 28, 2008 08:41 AM
wwglide
Sep 20, 2007 09:05 AM
HDF Tech
Jul 27, 2005 01:08 PM
