Carb/Jetting Help
Old Dec 31, 2010 | 02:07 AM
rocketmangb's Avatar
rocketmangb
Try this
http://www.hdtalking.com/fuel_and_ca...djustment.html
Old Dec 31, 2010 | 02:10 AM
rocketmangb
Also
See the little stylized mark on the jet ?
Thats a real Keihin jet and i wont use anything else.
I should send you a carb screw kit,is it expensive to ship to an APO ?
Old Dec 31, 2010 | 02:50 AM
cavalier2000's Avatar
cavalier2000
Originally Posted by rocketmangb
You really need the manual to adjust the float.
The adj is like .437 with the carbed tipped at a 20 degree angle
I have a manual on my computer so I will take a read though it. I take it I need something to measure the angle
Old Dec 31, 2010 | 02:53 AM
cavalier2000
I'm lost...
Old Dec 31, 2010 | 02:59 AM
cavalier2000
Also
It's the same as the states just use usps
Old Dec 31, 2010 | 03:06 AM
cavalier2000
I will take a look at it. I'm sorry trying to do too much on my phone gets me confused
Old Dec 31, 2010 | 03:07 AM
rocketmangb
pm me your address and i will send you some stainless allens to replace the cheesy phillips heads you have now.
As far as the carb angle goes just wing it and it should be close.
You may also have a problem with the intake seals
Old Dec 31, 2010 | 03:32 AM
cavalier2000
I have my old float somewhere I could check it out
Old Dec 31, 2010 | 06:09 AM
xFreebirdx's Avatar
xFreebirdx
This site will help loads with your carb.
Harley Davidson Performance
Old Dec 31, 2010 | 09:59 AM
cavalier2000
Ok so lets see if i am understanding this correctly...i need to make a wedge and place it on the counter
then i lay the carb on the wedge (lay the side that goes into the engine on it
then i measure out the distance i need....and if it is off i just bend the tab till it is right?
here is the pic from the one site that is listed above
