foot peg rubbed?
Today, I took a look to see how bad it is. I then found it is still pretty good.
As I mentioned, I feel it was rubbed very often, how can it be still good... Then I found two screws under exhaust pipe were rubbed.
They were rubbed very bad.
Does anyone have this same finding?
BTW, I am only 152 Lbs, not too heavy I believe.
Yeah been there done that , i actually snapped those little pegs off my footrests , and i still continued to scrape them further , yes the exhaust bolts also and the exauhst pipes as well . ive since changed my footrests to custom chrome ones and i still scrape the heck out of them. im on an 07 883Low this is all part of the fun of having a harley ride safe and enjoy every day
I am wondering, the foot pegs supposed hit earth first as design. Because it is foldable, so some tolerance won't lever the rear tire off the ground immediately, allow me to straight back up.
If the scaping is on those screws, if I lean hardly in some cases (emergency lean?) then for sure the bike will lose control.
the pegs supposed to be a warning, but, what I am saying, it is not happened as they supposed to be. My foot pegs are still in good condition.
I understand I am riding a cruiser bike, and have fun with it. Want to understand why foot pegs do not carry out its function, and worry about it will cause the bike slip down without a warning.
As TSD1959 said, I hit speedbump too yesterday. In same shopping center, first time I was shocked (oh, my bike
My 1200 low was very bad stock, and even after mods to increase the height, I still grind things from time to time.
I went from 11.5 inch rear shocks to 13 inch long ones, pushed the forks down and firmed them up, its better but not great.
Beware hard banked turns that compress the suspension, you might find yourself out of ability to lean and make the turn, and end up off the road.
It can happen really fast, the lean angle is poor to start with, compress the suspension and you can loose 2 inches more!
Leaning way over is great fun, it just feels great, but you cant do it on stock sportsters...
HD did just the opposite to appeal to those that like the rear fender very close to the tire, almost like a hard tail, and those that are short and still want to easily reach the ground.
I just put on a set of V&H straight shots (full pipes) and they have much better ground clearance than the stock pipes do as they use a different mounting bracket. So that is one route you could take if you are afraid to put the bike up on the exhaust in a tight turn.
And as far as taking "all the fun out of riding" is concerned, it all depends on what type of riding you're talking about. I find I really prefer the relaxed pace of cruiser-bike riding. I don't get pissed off at all the other traffic like I did with my sportbikes. Those bikes need to be ridden fast and blitz through the corners, they don't like to just motor along.
