rear tire size question
Old Feb 19, 2011 | 03:24 PM
mreed's Avatar
mreed
The Sportsters with mags that have a 150 tire have a rim that is only 3" wide. I've done it a few times with minor issues that were easy to overcome.
Also...I wouldn't space the sprocket with spacers. If you've done it with success you're lucky. You can have a proper spacer made or purchase one for around 20 bucks. BUT, the pulley doesn't need spaced.
Old Feb 19, 2011 | 03:49 PM
cpracing519's Avatar
cpracing519
I think I'm just gonna sell off my stock 16" tires from my bike and go buy her some new ones that will fit her bike. Looks like she needs a 130/90 16"rear and a 100/90 19" front.
Old Feb 19, 2011 | 03:54 PM
mreed's Avatar
mreed
Your front tire should work on the rear of her bike.
Old Feb 19, 2011 | 04:05 PM
cpracing519
never thought of that? Didnt realize you can use a front for the rear. Good Idea, Thanks!
Old Feb 19, 2011 | 05:42 PM
cpracing519
So 2 of my friends have told me that you cant put a front tire on a rear end. I kinda figured a tire is a tire? So what is the correct answer? Can you put a front tire onto a rear wheel as long as they are the same dimensions? Mine is a D402 MT90 and hers is a D401 130/90. According to internet surfing they are identical sizes.
Old Feb 19, 2011 | 05:46 PM
mreed's Avatar
mreed
The only difference is that the front tire is grooved to help move water on the roads out of the way.
What was your friends' reason as to why you can't?
Old Feb 19, 2011 | 05:52 PM
cpracing519
They just said that a front tire is a different compound than a rear. Didnt believe them, but started to wonder.
mreed's Avatar
mreed
You can call Dunlop & ask them if it's safe to run that tire on the rear. I've called Avon & Metzler & they told me what I needed to know about it.
Starting to turn in to a headache though.
Old Feb 19, 2011 | 05:55 PM
cpracing519
I will have to make some phone calls monday to check. Thanks for the info!
Old Feb 20, 2011 | 01:20 AM
REVHAPPY's Avatar
REVHAPPY
the 150 tire on a 48 is made for a 16x3.0 rim.(frt and rear 48 rims are the same size) same size rim on her bike, should work same swing arm,belt,etc...as every other 04 and up sportster. will look better then the 130 and worst case you mount the front on her rear. but better to try then to never have. its only a tire for crying out loud.......
04sedeuce
Jun 24, 2014 03:30 PM
Capt.Bob
30
Dec 20, 2013 05:38 AM
Superglide2012
Sep 5, 2013 05:23 PM
Streetbob Bomber
Oct 27, 2010 03:48 PM
mr. lowrider
Nov 10, 2008 01:10 AM
