Progressive or road king shocks
Old Feb 20, 2011 | 03:26 PM
empire_corsa's Avatar
empire_corsa
Default Progressive or road king shocks
Hi I am about to order my shocks and i want to know if the progressive 440 worth it or i should get road king shocks ( I have a 2011 48) and I will ride alot this summer, lots of long trips so help me please :P
THanks!
Old Feb 20, 2011 | 03:35 PM
HDCruzin's Avatar
HDCruzin
I went with the 11.6" Street Glide air shocks (Arnott Aldans). Same height as my stock and gives a great ride. Finally updated my pic to show them. I got them on eBay for about $80. You can see the chrome valve cap between the oil cover and the tank. I drilled a hole in the plastic wire cover to make easy access to pump them up when needed. I run about 30lbs air for 1-up and 40 for 2-up. Now I can ride without being disappointed in the stock shocks. I also just installed Ricor Intiminators in the forks. Both give a smooth ride.
Old Feb 20, 2011 | 03:44 PM
Pixiechitos's Avatar
Pixiechitos
I wanted the 440 but when I realized I could get RK shocks for half I jumped at it.
Old Feb 20, 2011 | 03:50 PM
barrachuck's Avatar
barrachuck
RK all the way!!! Love mine...
Old Feb 20, 2011 | 06:32 PM
wanabe's Avatar
wanabe
have works performance on mine. love how easy they adjust and the ride is great. they build them to your weight (in my case i had them built for a range of my weight up to mine plus my wife). they adjust by just a simple twist (so i can adjust from just me to 2 up too)
Old Feb 21, 2011 | 05:17 PM
hig4s's Avatar
hig4s
I didn't care about keeping the rear low, so I went with longer Progressives, I like them.
Old Feb 21, 2011 | 07:57 PM
1200Cdriver's Avatar
1200Cdriver
I went with the Progressive 440 standards in the 13.5" length, no more spine jarring on bumps, no more squat on take off. They are a perfect compliment to the Progressive fork springs and BelRay 7w fork oil.
Old Mar 31, 2012 | 03:23 PM
D2wing's Avatar
D2wing
I just installed Road King air shocks on my Low. The spring rate is about 15-20lbs more than stock so the ride is not smoother. They do absorb big bumps better with a little air 5-7 lbs psi, and they do not bottom out. Good for 2 up but
If you want smoother I'd go with 12.5 inch Proggressive or Works with the lower rated springs under the 75 lb stock rate. It does handle a little better with the RK's over stock. I had 12.5 on another Sporty and they were smoother than either the RK'S or stock. This time I am thinking about 13 inches and longer forks. I am on the verge of going to an Electraglide as I have a bad back.
6 gun
Sep 11, 2018 06:39 PM
djwhaley
Nov 9, 2013 10:33 AM
robbieaz62
Apr 5, 2011 06:16 PM
dog155
Jan 7, 2007 08:31 AM
vharrig
May 23, 2006 04:42 PM
