Air shocks
Old Nov 7, 2013 | 08:51 PM
djwhaley's Avatar
djwhaley
Default Air shocks
For those that have switched to touring shocks, which are better on the dyna road king or street glide?
Old Nov 8, 2013 | 03:41 AM
beagle01's Avatar
beagle01
The road king shocks are 13", the Street glide are 12", the same height as the FXD's.. 13" shocks do look a bit high as they lift the back up over 1" because of the mount angle.
Old Nov 8, 2013 | 04:47 AM
charlie46's Avatar
charlie46
6th Gear
I'm 260 lbs. The shocks on my SG afford a very stiff ride due to heavier springs needed for lack of travel over the longer RK shocks. I switched to 13" Progressive air adjustable shocks..Much smoother ride.
Old Nov 8, 2013 | 05:31 AM
1HD1C's Avatar
1HD1C
running the 12" street glide shocks on mine.. very happy AFTER i changed the 5wt stock oil out to 10wt
Old Nov 8, 2013 | 06:52 PM
Junkster's Avatar
Junkster
I'm running the road king 13" take offs. Simply because a buddy gave them to me. I like them. Bike sits a freckle higher but is not an issue.
Old Nov 8, 2013 | 09:33 PM
MidevilX68's Avatar
MidevilX68
Default Shocks
I am thinking about putting street glide shocks on my fat bob anybody know if they will fit its 2013 and will it ride better than the stock shocks I ride 2 up alot
Old Nov 8, 2013 | 09:43 PM
djwhaley's Avatar
djwhaley
what psi do you run? Im 195lbs
Old Nov 9, 2013 | 05:08 AM
1HD1C's Avatar
1HD1C
the late model shocks which i have ( i believe 08 and up) can go up to 50lbs.
after the oil change i run 20-22 solo and 22-25lbs with wife on back
i weigh 160-165 and wife is dare i say 135..
before shock oil change it rode like a baby carriage, too bouncy..
Old Nov 9, 2013 | 10:33 AM
Junkster's Avatar
Junkster
I also have late model pair. I'm 210 run 20 solo 25 2 up. Heavier oil definitely helps. Some what of a pain in the rear to do though. I think it may be 09 and up. Either way riding on air way better than stock shocks.
pontiac69
Mar 30, 2016 01:58 PM
BKSinAZ
Aug 16, 2014 07:05 PM
robbieaz62
Apr 5, 2011 06:16 PM
freman10
Jan 5, 2011 04:01 PM
Garemlin
Aug 19, 2009 05:39 AM
