Did rocker cover gaskets, hope I did good!
Old Mar 13, 2011 | 06:55 PM
Bobber Jake's Avatar
Bobber Jake
Default Did rocker cover gaskets, hope I did good!
Well I did my rocker cover gaskets today. The front was leaking pretty good last season. Well I found out why when I took the front cover off, one of the bolt had backed itself almost all the way out. Then the torque wrench I used was junk. First I broke off a bolt in the jug and had to figure out a way to get it out. I used a dremel and put a slot in it and was able to get it out with a flat head screw driver, thank god. So then I got the wrench to work and managed to torque the 4 main bolts down however the other ones would not snap with the wrench and I did not want to risk snapping another bolt off so hopefully they are torqued right otherwise I will be doing them again. I will say they were easy to do though. But make sure you have a service manual.
jlasoftail
Feb 3, 2014 10:00 PM
mpaquette
Apr 2, 2013 09:44 PM
Nightster Ridester
Dec 27, 2009 08:21 AM
db45
EVO
Nov 5, 2009 12:41 PM
fob_speicher
Jun 23, 2007 08:34 PM
