Front Locking Up - Help Please!
Old Mar 28, 2011 | 03:03 PM
1CdnHD's Avatar
1CdnHD
If you take the top of your master, carefully apply and release the brake, check for fluid returning in the reservoir. If relieving system pressure by cracking your bleeder screw allows your caliper piston to return, the caliper is working OK and the pressure is being maintained by your master.
Old Mar 29, 2011 | 06:43 AM
Spur56's Avatar
Spur56
Originally Posted by tony2x
so if I understand you correctly, if I push fluid from the bleeder on the caliper up into the master cylinder, I should be able to identify an issue with the relief port?
I use this method to bleed/flush my brake systems. From your description it appears you are getting a hydraulic lock. If you cannot get fluid to flow from the bleeder back into the Master Cylinder then you have some kind of blockage. It is just an option in your troubleshooting. As I stated I have use this method many times, just don't try and put too much fluid too fast through the bleeder, just slow and steady. Also be careful not to overfill the master cylinder, it makes a mess.
Old Mar 31, 2011 | 04:40 PM
tony2x's Avatar
tony2x
5th Gear
thanks for all the suggestions ... I actually dislocated my shoulder the other night so can't do much for the next 3-4 weeks...will let you know how it all turns out and what the problem was
Old Apr 1, 2011 | 09:33 PM
stbobber's Avatar
stbobber
Same thing with my 06 streetbob, kept locking up, I changed the fluid but now have trouble bleeding it.
Old Apr 1, 2011 | 09:41 PM
Fatboy Brian's Avatar
Fatboy Brian
Originally Posted by DR. V-TWIN
I had the same problem on another brand bike I owned and it was a hairline crack in the MC. New master cylinder fixed. I am not saying this is your problem, but something worth checking for.
Drew
Same thing. Its in the MC, May be easier just to replace it with new.
Old Apr 4, 2011 | 01:59 PM
tony2x's Avatar
tony2x
5th Gear
Do you mean replace the reservoir/MC housing itself? I have already rebuilt the master cylinder and it was still locking up
Old Apr 4, 2011 | 02:18 PM
Fatboy Brian
I had the same exact symptoms you are describing happen on my bike 2 years ago after installing a new chrome control setup. A brief decryption of what was happening on my bike. I could bleed the brakes as per the manual. I would go for a test ride and as soon as I applied the front brake it would stop fine. As soon as I released the brake it would start building pressure to the point that the front wheel would lock up. I had to carry a wrench to brake the bleeder screw loose to relieve the pressure so that the brakes would release. Start down the road again and as soon as I applied brakes same thing would happen again. I exchanged for another new Master cylinder and problem solved.
Old Apr 7, 2011 | 09:31 AM
tony2x's Avatar
tony2x
5th Gear
thanks man, sounds like the same exact thing
Old Apr 19, 2011 | 01:25 PM
tony2x's Avatar
tony2x
5th Gear
Thanks for all the help everyone...problem fixed. I bought a new master cylinder assembly and new reservoir cap/gasket/sight glass and the problem is gone...so happy
Old Apr 19, 2011 | 04:21 PM
simmy711's Avatar
simmy711
Daytona Glider
Feb 3, 2023 07:43 AM
hdultraclassic
Shovelhead
11
May 11, 2019 08:25 PM
JMAY_ATL
Ironhead
Sep 29, 2014 06:09 AM
HamToast
Feb 23, 2013 05:37 PM
frogg
May 31, 2009 01:30 AM
