HELP !! electrical---wont start
Old Apr 22, 2011 | 12:17 PM
BINGO53's Avatar
BINGO53
Question HELP !! electrical---wont start
'07 883C, 800miles:
I need some direction and informed guidance here. As you can tell, the bike sits alot (800 miles in 5 years) Ive charged the battery. I have intermittent flash of the digits on the odometer. A weak headlamp. No turn signals, and needless to say NOTHING for starting. Not even a whirr or a whimper.
I've checked the master fuse, checked the contacts for corrosion on the starter fuses. Can someone give me some "informed" guidance/direction as to where to look next? Where are the grounds located, any common connection trouble spots?
Your help would be greatly appreciated. Id really like to go riding this weekend. :-)
Respectfully submitted,
BINGO53
Old Apr 22, 2011 | 12:28 PM
Iceman24's Avatar
Iceman24
Bingo; re-check your battery connections & ensure they're tight. Also, double-check battery load to ensure it's actually fully charged (should read ~12.7V). My guess is you have a bad battery (cells)...
Old Apr 22, 2011 | 01:39 PM
BINGO53's Avatar
BINGO53
Thank you Iceman. My intuition goes along with you. Due to age of the battery and such, I'm going to try to find a new one this weekend. However, I was hoping someone would chime with where to look next of that doesn't solve the problem.
Respectfully,
BINGO53
BTW: This is a friends bike, I'm buying him a tender and QDharness for Easter!
Old Apr 22, 2011 | 03:42 PM
Grammaton's Avatar
Grammaton
If the headlight is dim the battery is dead/dying. An apparent full charge can be depleted immediately if one or more cells are bad.
Old Apr 22, 2011 | 07:24 PM
Von_Zipper's Avatar
Von_Zipper
Yes, if the battery has been sitting discharged it's dead. There is nothing you can do to resurrect it.
Old Apr 23, 2011 | 12:32 PM
BINGO53's Avatar
BINGO53
Thank you all for your replies.
The battery checked out fine. However due to its age, just for good measure it was replaced with a new one.
The culprit turned out to be the ignition switch. Replaced it....ready to ride tomorrow.
Thanks again,
BINGO53
TP2508
Electrical/Lighting/Alarm
Jul 12, 2019 06:56 AM
Brayfield
Oct 15, 2016 09:59 AM
VirtualNorm
Oct 14, 2010 06:47 AM
hdpearson13
Ironhead
Dec 2, 2007 05:48 PM
HeatherC
Sep 23, 2005 12:16 AM
