Question about changing bars
Old Apr 24, 2011 | 07:24 PM
low_wgn's Avatar
low_wgn
Default Question about changing bars
I have done a bar change before but not internal wiring. I have mini HD apes on my nightster now and i am going to apes that i will not have to change out any cables or get longer wires. What exactly do i do when taking the bars off as far as the internal wiring? How hard is it? I am pretty good at mechanical stuff just never done this before. Can i get some help
Old Apr 25, 2011 | 09:20 AM
stevelonewolf's Avatar
stevelonewolf
Before you remove the bars,you're going to have to detatch the H-bar wires from the harness or clip them. Then remove the H-bars. If you plan on reusing the same wires,be careful when pulling them out from the top of the H-bars as there may be burrs on the lip of the holes from drilling them out and can snag on the wire coating. If you want,you can spray a little WD40 in the top and let it run down so it can be easier to slide out. When installing the wires in the new bars, take a long ribbon and an air gun and blow that ribbon from the top hole and ut'll come out the bottom. Tie the top end of the ribbon to the wire's end and tape it with a little electrical tape and slowly pull the ribbon through the bottom being careful of any burrs you may have missed when you cleaned up the openings of your new H-bars. I think you get the gist of what's going on...
Old Apr 25, 2011 | 05:38 PM
low_wgn's Avatar
low_wgn
will i have to take them out of the harness?
Old Apr 25, 2011 | 06:42 PM
stevelonewolf
Well, the wires plug/connect to your wiring harness. You can always carefully snip them and butt end connect them when you are done putting them through your bars..
dlt6855
Mar 17, 2018 03:27 PM
Powertrip240
2014-2024 Touring Models
27
Mar 16, 2016 07:38 PM
Brian MD.
Jul 29, 2014 07:11 PM
smokinfromshootin
Nov 20, 2010 09:01 PM
thexman10
Mar 10, 2009 09:50 PM
