Fuel choice
The bottom line - better stay away from low octane. If you need to use it do not drive it hard.
Another question is - do I get the fuel I'm paying for? The truth here is there is about 0.5 gal of previous fuel in the hose and pump, in case of common hose. You must be very lucky if someone pumped premium before you. Normally it was regular and with our peanut tank you'll get mixture of 25% regular / 75% premium when pumping 2 gal.
Tip: Look for gas stations that have separate hoses.
As for pinging, high octane is not usually required. most vehicles will do perfectly fine without it. It is only high performance cars, cars that have been custom tuned, or recreational vehicles that tend to run hot that high octane fuel is required. Harleys are air cooled, therefore could benefit from higher octane fuels. You can always run higher octane, just not lower. Ethanol slows the fuel rate which decreases detonation (pinging), but this is also a way that the gas companies rip America off. They are allowed to use inferior, lower octane gasoline because the ethanol brings the rating back where it is rated at. You are paying for inferior gas that burns faster and costs more and more at the pump.
always fill from reserve.
You top off two or three times In a row,,,1 gallon at a time yer octane level Is 90,,Imagine that
An 883 efi or carb may do fine on 87,,
But a 1200 EFI,,,needs 93,,,
You keep putting 87 in a efi1200 and you may,,,just may start
building carbon on the piston top..
Ping hell,,,can you say "I Cracked a Piston"
Got a Marina near by ?
If So Grab a 5 gallon can, jump in yer cager an get some
Non ethanol premium fuel off the docks.
Before ya put It In yer tank drain the 10% ethanol into a container,,
Set both about ten feet apart,,
NOW don't be stupid about this,,,,go take a whiff,,,thats a SMALL sniff
of each fuel.
You don't have to stick yer snozola right into the hole just get near it.
The difference In smell will freak you out.
Ethanol sucks.
Oh yeah The Bike will run different,,specially carbes bikes,,,,
of each fuel.
Ethanol sucks.
Dammit Man !!!
I ain't never smelled that stuff,,,cool
Engines are designed to run certain octane of fuel. Think of this as shoe fit. You do not want it big nor small, it has to be just right.
Our Sportster engine is designed for 92, so that's the correct octane for us.
Running lower octane creates ping, which is detonation, an unwanted process. Depending how severe it is it may destroy piston rings, damage pistons and connecting rod bearings.
Running higher octane than designed for your engine is less dangerous, it just burns a little slower, in extreme cases it may burn your exhaust valves, normally you just lose a tiny bit of fuel economy.
