what octane do you use?
Old Apr 28, 2011 | 04:36 PM
streetfighter06's Avatar
streetfighter06
883's are rated to burn 87. read the manual...
Old Apr 28, 2011 | 09:00 PM
3skulls's Avatar
3skulls
The manual that came with my 883 says...
Refer to table 18. Always use a good quality unleaded gasoline. Octane ratings are usually found on the pump.
Table 18. Octane Ratings
Pump Octane (R+M)/2 91 (95 RON)
Old Apr 28, 2011 | 09:06 PM
OV-10's Avatar
OV-10
For my '07, the owner's manual says use 91 octane, so that's what I use.
Old Apr 28, 2011 | 10:02 PM
Wildman4x4nut's Avatar
Wildman4x4nut
Maybe your 2006 manual says to run 87 but those of us with 2007 manuals who can read see that it says to run 91. So I guess we can read.
Old Apr 29, 2011 | 07:12 PM
midnight2005's Avatar
midnight2005
ok no need to fight about it. thanks for all of the input. I do not know what milage my bike is getting but since I put the new ac and PCv, it does not get as much as it used to. My car gets about 30 mpg and I run 80 miles a day. Riding the bike, I usually run faster so that makes a difference. Thanks for all of the help.
Old Apr 29, 2011 | 07:18 PM
kountry's Avatar
kountry
Living in Cali with gas so high I run the cheapest every other tank
Old Apr 29, 2011 | 10:52 PM
lh4x4's Avatar
lh4x4
The ECM is able to adjust from 87 to 91 octane. In a stock motor 93 is a waste.
I run 89 in all of my bikes and have 10's of thousands trouble free miles on them from Alaska to Key West. Never a ping. All start and run strong.
Old Apr 30, 2011 | 08:04 AM
Hawg295's Avatar
Hawg295
Originally Posted by joel85
I run 93 octane usually Shell. Manual says to ruin 91+. If 30 cents a fill up really breaks me then I should probably consider getting rid of the motorcycle.....
I run 93 octane. For a few extra cents I know it's going to run good.
Old Apr 30, 2011 | 08:48 AM
TSD1959's Avatar
TSD1959
All winter I've used either Chevron or Shell 89 octane mid-grade and engine runs fine. I do always add a splash of TCW-3 2-stroke oil to most tankfuls (always add it to my Ranger too) just to help lube the fuel pump and valves.
As the temps stay above 90* then 100*+ for the next 6 months, I will convert to using 91 octane premium to prevent any preignition.
Old Apr 30, 2011 | 08:57 AM
dp2826's Avatar
dp2826
does it not run good on 91? do you think it runs "better" on 93
