Poor brake performance
Old May 14, 2011 | 04:20 AM
DavidStiebel's Avatar
DavidStiebel
Exclamation Bill's brakes
Originally Posted by Billy...
The brakes on my 92 Sportster are not that great. I can get the back brake to lock up only if I stand on it and I doubt that I could get the front to lock even if I gripped it with both hands.
They do slow me down OK but that's about the extent of it. They certainly don't seem to inspire a great deal of confidence in the bikes stopping ability.
Is this normal for a Sportster or should I be looking for an issue with them?
Sir,
do 2 things,
1. change the brake fluid after checking for leaks or bad brake lines & connections.
2. check to see the pads are installed properly, in the wrong location they do not work well.
The brakes on the bike are adequate to the task as long as the mechanic is up to the task.
Regards, David
Old May 14, 2011 | 06:51 AM
Osco's Avatar
Osco
Account Deactivated
Cool
Take the calipurs apart,,clean and re lube the pin also,,
Change out the brake fluid completly,,
Clean the disks with simple green or brake cleaner or vinegar..
I clean mine every bike wash and can feel the difference......
If pads are below 50% change em,,calipur won't have to move as far..
Changing to stainless steel wrapped brake lines will reduce line expansion.
If I use anything more than foot muscles on my rear It locks..
Last single disk custom I rode,,the front brake was lockable with a
decent squeeze.
My dual disk fronts,,stopping Is a two fingerd affair.
If you decide to go dual fronts remember the master cylinder you have
cannot move the volume of fluid the dual disk system needs.
Old May 18, 2011 | 07:26 AM
Billy...'s Avatar
Billy...
Originally Posted by CapnAdventure
Why would you want to lock the brakes? Locking brakes means longer stopping distances as you are sliding, thus lack of control. Locking brakes will flat spot your tires. Why do you think auto and bike manfactuer's have ABS systems? Ideally, the best stopping performance is at the point of impending lock-up, but not at lock-up.
I don't WANT to lock them Capn I was purely saying that IF I wanted to I couldn't even if I squeezed as hard as I could. I was trying to get a feel for whether this is typical for Harley brakes or something unique to mine.
I suppose I could look on the bright side and consider it as a sort of ABS style system.
Old May 18, 2011 | 07:29 AM
Billy...'s Avatar
Billy...
Thanks for all the replies guys. I think I'll have the system apart and renew some bits. It sounds like I should expect better performance than I'm getting.
MotoArts
May 9, 2019 07:15 PM
mick_dundee
Oct 1, 2013 09:08 PM
Bobino
Apr 9, 2011 12:01 PM
LateBloomer
22
Apr 30, 2010 05:05 PM
SunRa73
Sep 27, 2008 10:46 PM
