2011 sportster 48 occasional misfire
Old May 21, 2011 | 12:01 AM
bwatte's Avatar
bwatte
6th Gear
Default 2011 sportster 48 occasional misfire
I just put short shots, stage 1 and fuel pak on my 48. I screwed up and forgot to put gaskets in between throttle body and stage 1 back plate, so for about 100 miles it had about an 1/8" gap where air was getting sucked straight in without going through the filter. So I assume all the air wasn't getting filtered and it was getting too much air flow.
Since I fixed this I notice I get an occasional misfire when on the road and it just seems like when I'm at a constant speed the spark plug isn't performing at 100%
Is it possible that I could have messed the plugs up when the bike was getting too much air? It really seems like it could be the spark plug so I was just wondering if my screw up could have negatively impacted the plugs
By the way my fuel pak settings are correct for my configuration
Thanks
Old May 21, 2011 | 11:48 PM
Scuba10jdl's Avatar
Scuba10jdl
It's pretty easy to check out the spark plugs. Pull them out and look at them. If they are bad, just swap them for a new set (only around $5 total). I doubt this is the problem, though.
It most likely just lean running conditions. Does it sort of "pop" and "hiccup" while you're just cruising along? That would be an indicator it is still too lean.
Stvnb74
Sep 13, 2018 11:49 AM
crcraig
Feb 19, 2016 12:11 PM
easttnrhino
Exhaust System Topics
Apr 8, 2013 10:59 AM
2011Iron883
Mar 27, 2011 11:04 AM
Arizona
Feb 24, 2007 07:42 PM
