cheap do it yourself front turn signal relocation.
Old May 27, 2011 | 01:55 AM
boduke883's Avatar
boduke883
ok cool thanks. I'll try an Ace tomorrow
Old May 27, 2011 | 02:08 PM
JayPMack's Avatar
JayPMack
Quick question, how much relocating or rewiring of turn signal wires was required. I assume you have to run the wires through the forks somehow?
Old May 27, 2011 | 03:35 PM
blacksportster05's Avatar
blacksportster05
ya just unhook the connector under the tank and pull it out and reroute the wire hook the connector back up.
Old Jun 6, 2013 | 12:23 AM
Rustygold's Avatar
Rustygold
Is the parts list got a error because these are no were to be found only in 1/4-20 no 1/4-16
(((two all thread coupling 3/8-16 on one end and((( 1/4-16 ))))on the other)
Old Jun 6, 2013 | 11:47 AM
Davemac122383's Avatar
Davemac122383
I did this exact mod last year with the same parts. I bought all mine at Value Hardware Store, cost was less than 10 bucks, but I also added auto rubber caliper bolt covers to the studs.
Old Jun 6, 2013 | 11:54 AM
jdub099's Avatar
jdub099
I have a general signal question for the ones that hang down from the controls. Do the pegs that go up into the hole on the controls unscrew from the signal body? Thought I'd ask before twisting away.
Old Jun 6, 2013 | 12:26 PM
Rustygold's Avatar
Rustygold
There is no such coupling at 1/4-16 only 1/4-20. Do you cut down or something missing from parts list
Old Jun 6, 2013 | 01:29 PM
Zane Nelson's Avatar
Zane Nelson
Nice home mod for sure! Figured I would post this also just in case some of you cant find the parts at your store you can always go the route of amazon for surprisingly cheap parts as well. Heres an actual fork relocation bracket that should fit just fine also.
Black Fork Turn Signal Clamp-on Mount for Harley Dyna Sportster 39mm Relocation : Amazon.com : Automotive Black Fork Turn Signal Clamp-on Mount for Harley Dyna Sportster 39mm Relocation : Amazon.com : Automotive
Old Jan 17, 2014 | 04:38 PM
Arrampico's Avatar
Arrampico
Default Another Option too....
https://www.hdforums.com/forum/sport...l#post12210562
Here's a link to how I did mine....also about $5...
PM me if you got questions....
Attached Thumbnails cheap do it yourself front turn signal relocation.-img_0955.jpg   cheap do it yourself front turn signal relocation.-img_0958.jpg   cheap do it yourself front turn signal relocation.-img_0966.jpg
Old Jan 17, 2014 | 04:48 PM
DK Custom Products's Avatar
DK Custom Products
Sponsor
Here is another idea if somebody does not want to fab up their own, or wants to change out the these turn signals.... they are also offered in chrome.
CLICK ME
__________________
www.DKCustom.com
662-252-8828 Voice
662-420-4891 Text & Voice
Support@DKCustomProducts.com
