cheap do it yourself front turn signal relocation.
Old May 22, 2011 | 06:25 PM
blacksportster05's Avatar
blacksportster05
Default cheap do it yourself front turn signal relocation.
Parts list(a power drill,4inchs of 3/8 all thread,two all thread coupling 3/8-16 on one end and 1/4-16 on the other,two 1and a half long 5/16-24 bolts,a 5/16-24 tap,and 19/32 drill bit,and a hack saw.
first you want to cut the all thread to inchs long screw it in where the pinch bolt used to be till it bottoms out then put the all thread coupling on the all thread tighten up then drill out the other side of the coupling make sure your drilling straight then tap the hole.Cut the 5/16 bolts head off thread it in the coupling put the turn signal on and tighten repeat on otherside and done.
Attached Thumbnails cheap do it yourself front turn signal relocation.-2011-05-18_17-52-47_328.jpg   cheap do it yourself front turn signal relocation.-2011-05-18_17-52-59_529.jpg   cheap do it yourself front turn signal relocation.-2011-05-21_18-43-11_391.jpg   cheap do it yourself front turn signal relocation.-2011-05-21_18-43-16_656.jpg   cheap do it yourself front turn signal relocation.-2011-05-21_18-42-51_352.jpg
Old May 22, 2011 | 06:29 PM
streetfighter06's Avatar
streetfighter06
No pics? BOOOOO!
Old May 22, 2011 | 07:03 PM
blacksportster05
Originally Posted by streetfighter06
No pics? BOOOOO!
sorry i started the thread on my phone and it wouldnt let me put pics in here you go.
Old May 22, 2011 | 07:37 PM
tripn88's Avatar
tripn88
nicely done thanks for this.
Old May 22, 2011 | 09:38 PM
jthepipeguy38's Avatar
jthepipeguy38
Now that I can do
Old May 22, 2011 | 10:03 PM
quan00's Avatar
quan00
well done!
Old May 23, 2011 | 11:44 AM
stonewall308's Avatar
stonewall308
I relocated my front turn signals to a cardboard box in my garage.
Old May 23, 2011 | 04:20 PM
gravitystrykes's Avatar
gravitystrykes
Good idea! might have to try it!
Old May 26, 2011 | 01:26 PM
boduke883's Avatar
boduke883
Do they make a coupling with 3/8-16 one end and 1/4-16 on the other? I went to home depot and could only find a 3/8-16 both ends
Old May 26, 2011 | 09:06 PM
blacksportster05
ya if you have any smaller store like ace thats where i would go. i found mine at theisens its a local farm store.
