'79 sportster kickstart problems
Old May 23, 2011 | 12:19 PM
79olschool's Avatar
79olschool
Stage II
Default '79 sportster kickstart problems
is there a way to keep kicker from nearly breakn ur ankle without buying starter? i also need to adjust s&s super carb, gettn alot of gas spittn back into filter causing filter to get soaked. this is my first bike and have done alot of mechanical work to it. it didnt run when i bought it. guy said it hasnt ran in a yr. changed out dyna s ignition and it fired up. my main concern is the gas and clutch cable tightening up while riding. checked adjuster screw and nothing there. stays tight. any help is much appreciated.
Old May 23, 2011 | 12:47 PM
Blackcherry Low's Avatar
Blackcherry Low
Kickers on these bikes are known for not engaging very well, mine always engages real well at about the 9 o clock position. You don't get much of a stroke like that but if she's well tuned, that's all it needs. Once you've got it engaged, keep a light downward pressure on it, if you jump up and lose that pressure, most of the time it will slip and really knock the **** out of your inside knee bone on the upper shock mount.
As for your clutch problem, you'll probably need to pull the primary cover off to see what's going on inside there.
I have no experience with the S&S carb, lots of guys have trouble with them. Mine has the stock carb.
Congrats on the new Ironhead ownership, there is a seperate section here for them too by the way.
Old May 23, 2011 | 01:00 PM
79olschool's Avatar
79olschool
Stage II
thanx blackcherry. i can usually get it to kick real easy but when it gets to certain point, itll kick the crap outta me. dont have much problem with super carb except the lil shower. took off cover and dont see any problems with clutch. first time i rode, i rode probably 10 miles with no clutch problems. next day is when it started. ill check out ironhead section.
Chainsaw06
Mar 16, 2019 06:55 AM
hobo1
Shovelhead
25
Aug 11, 2016 07:04 AM
aconnor303
Shovelhead
Nov 17, 2014 11:12 AM
kizzletruck
Ironhead
17
Apr 26, 2011 11:34 PM
dm76
Mar 30, 2010 04:48 PM
