Forward Controls & Mini Floorboards
Old May 25, 2011 | 11:03 PM
jalochhead's Avatar
jalochhead
Default Forward Controls & Mini Floorboards
How do I rotate my foot controls to allow my boot to get underneath my shifter peg? Installed mini floorboards, like them, but having trouble getting my boot underneath --
Pics underneath
Attached Thumbnails Forward Controls & Mini Floorboards-left.jpg   Forward Controls & Mini Floorboards-right.jpg
Old May 26, 2011 | 01:10 AM
MrCookie's Avatar
MrCookie
might have to go with a heel toe shifter.
Old May 26, 2011 | 01:20 AM
garslayer's Avatar
garslayer
To adjust the floorboards, loosen the screw and rotate on the splines to fit your needs. Have them on my bike and did this for my comfort.
Old May 26, 2011 | 01:21 AM
Ragnar Danneskjöld's Avatar
Ragnar Danneskjöld
I'd probably just create a small bracket to modify the angle of the forward controls.
Old May 26, 2011 | 02:27 AM
R_man's Avatar
R_man
There is an adjustment screw on the side of the floorboard. Take that out, then pull outward on the floorboard until it comes loose. Rotate it slightly and then push it back on the support shaft and replace the adjustment screw.
If you find that you still need room for your boot, you can adjust the shift linkage.
Old May 26, 2011 | 06:25 AM
HDCruzin's Avatar
HDCruzin
I had same issue. Rotate like posts described and will solve it. No need to modify shifter.
smknflms
Aug 7, 2020 06:18 PM
HectorBuddy
Sep 10, 2013 11:07 AM
lowrider2006
Feb 28, 2009 11:03 AM
old man sporty
Apr 6, 2008 10:52 AM
Garemlin
Nov 25, 2007 08:08 PM
