Every time you ride your bike and it's subjected to a heat-up / cool-down cycle, moisture can and will form in the oil system, assuming your in something other than a 0% humidity environment.
Remembering that water boils at 210*F, the only way to rid the oil of the moisture is for it to reach that 210* temp. No, that doesn't mean your dipstick temp gauge needs to reach 210*, because as the hot oil is returned to the tank and mixed with the somewhat cooler tank oil and the temperature will drop.
In approx. numbers, you want to see at least 180* for the tank temp. in order to ensure that it's getting hot enough to boil off the moisture.
This is the same reason that it's never a good idea to occasionally fire-up a stored bike in the winter. You'll get it just hot enough to cause moisture to condense in the oil system, but not hot enough, long enough, to boil it off.
Hey everyone. Got a question... I own a 2002 XLH 883. Has anyone have an idea what is the best Oil Temp range?? Just bought an oil temp guage and shes been running at 150-155 degrees, and I'd like to know if this is within good limits or not. Thanks in advance.
Take that Oil temp guage and test It,,,Pot O water on the stove,,
It boils at 212 at sea level,,
I would think at best those analog guages are +-10% at best
I would also bet yer guage tells you the boiling water Is about
160 degree's,,,,,,,
cHarley, When I park my truck I always park it so I won't have to move it for someone to get out of my driveway. As you said that is hard on the oil and really hard on the battery.
My bike and truck are lucky that way, I live 35 miles from every where.
Reason: Spelling
Let us be clear that bike gauges like voltmeters, oil temp and pressure gauges are not very accurate. Best not to look at them, frankly! My favourite indy calls them 'worry gauges'. Ride and enjoy - your bike will be fine in all but the very most extreme conditions, when most of us will not go riding.
Oil temp is kind of dependent on the air temperature as warmer air will not cool the engine as much. it's been in the 80-90 degree range here and i see oil temps up to 220 on the hottest days.
