Starter grinds and smoke out the carb
Old Jun 8, 2011 | 11:50 AM
JokerRides's Avatar
JokerRides
Default Starter grinds and smoke out the carb
1999 1200 custom
I just put new dyna coil and ignition now my starter grinds and smoke out the carb .
tuned it up three times , still have problem. Dosn't do it all the time. a guy told me to get a "starter booster relay" what do you think?
Old Jun 8, 2011 | 12:24 PM
cHarley's Avatar
cHarley
If something is grinding, I doubt a "starter booster relay" will be any help. I'd suggest checking out the starter and starter clutch.
Old Jun 8, 2011 | 12:36 PM
JokerRides's Avatar
JokerRides
Well it really don't "grind" it kinda hangs up
almost like theirs too much compression
i will check into starter clutch. Thanks
Old Jun 8, 2011 | 01:26 PM
cHarley's Avatar
cHarley
If it only does this when restarting the motor when the motor is hot, like when you turn it off for a short time for a quick gas fill-up, this is pretty common on 1200s. The HD starters are marginal at best when it comes to handling the 1200s higher compression.
It will eventually strip the starter clutch gear and require replacement.
Old Jun 8, 2011 | 01:45 PM
Bo Joe's Avatar
Bo Joe
cHarley,
Is there a better starter to buy?
Old Jun 8, 2011 | 02:30 PM
cHarley's Avatar
cHarley
Originally Posted by Bo Joe
cHarley,
Yep, I replaced the whole starter at 25,000 miles after striping the 2nd starter clutch.
The best starter IMO, is an "All-*****" brand 1.4kw. It's been 50,000 miles since I installed the All-*****, and I've not have a hot start / kick-back issue since.
There not cheap, about $260.00 last time I looked, but when you look at the labor hours to pull and reinstall the starter several times, $260.00 becomes a lot cheaper.
Old Jun 13, 2011 | 03:12 PM
JokerRides's Avatar
JokerRides
i heard the all ***** starters are a rip off.
Alan7407
13
Mar 18, 2026 07:12 PM
cuznleroy
Nov 9, 2012 11:07 AM
andyp
Sep 13, 2009 10:05 PM
zenon9
EVO
Dec 30, 2007 05:05 PM
02glide
Oct 26, 2006 01:00 AM
