Which gas?
Old Jun 27, 2011 | 07:43 PM
  #31
IronHorse570's Avatar
IronHorse570
Av gas is actually good for old ironheads if blended properly it has plenty of lead in it required by the old valves. I ran 50/50 mix of av gas and 93 octane in my old IronHead. Now its just 91 or 93 octane in my 90 1200 sporty. Can honestly say it does not like 87 or 89, it will run but performance it sacrificed when running lower grade fuel. Not going to worry about a few cents when filling my tank. Not worth a big debate over run what you want in your bike. Personally I run better higher octane fuel because it performs better in my opinion.
Old Dec 3, 2011 | 10:24 PM
  #32
gas4harley's Avatar
gas4harley
6th Gear
Default Amoco is not what it use to be.
Originally Posted by BreezyKollins
I use 93 from BP in my bike. I use BP exclsively in all of my vehicles, bikes, boats, mowers, etc..... it just burns cleaner with less carbon than any other brand. Its actually the old amoco blend formula that BP kept using after it bought out amoco.
The old Amoco gas use to be the best. It was pure clear like water. Take some BP 93 today in a glass and look at it. Not the same, not as pure. Besides BP is a scumbag company! Just my opinion. Go with Shell, Chevron or Texaco 93.
Old Dec 3, 2011 | 10:50 PM
  #33
BAKERiSM's Avatar
BAKERiSM
Originally Posted by Challenger
I run jet fuel. My bike is vivid black and therefore goes faster and can use jet fuel. I do not recomend this for anyone else though
Hahahaha yesssss!!
Old Dec 3, 2011 | 10:51 PM
  #34
TKDKurt's Avatar
TKDKurt
93 octane from a brand name station. I don't care which one, but I won't put Costco, 7-11 or other cut rate gas in. Gasoline may be gasoline, but the additives that are put in keep the fuel injectors clean on my bike and in my cars. The difference between the cutrates and the brand names are the additives.
Old Dec 3, 2011 | 11:04 PM
  #35
Mich's Avatar
Mich
I was warned away from any gas with high amounts of Ethanol so I run Chevron up here in Canada. I always run the 94 octane instead of the minimum 91. I figure it's worth spoiling my bike since it is only an extra 25 cents per fill up.
Old Dec 3, 2011 | 11:12 PM
  #36
VirgeB's Avatar
VirgeB
You are correct. My dad has worked at refineries all he life and gasoline is gasoline. All different companies get their gas from the same refineries and the only difference is their specific additive that they put into it.
Old Dec 4, 2011 | 02:26 AM
  #37
SportyPig's Avatar
SportyPig
If your bike is designed to run on 87 Octane, which mine was when stock, running a higher octane fuel is just a waste of $$. Now that the bike is a 1250, and running a 10.5:1 compression ratio, it required 92 octane. It wouldn't start on 87 Octane fuel.
In general, I have noticed slight improved performance and mileage on Shell gas. If you can find non ethanol, that is more important than brand. I TOTALLY avoid Citgo, but that has to do with politics, not the fuel.
Old Dec 5, 2011 | 12:55 PM
  #38
Thumper26's Avatar
Thumper26
My manual says my 2005 1200 Roadster needs 91 octane, so that is what I use. I buy mostly Shell, and once without thinking I filled up with 87 octane (what I use in my truck). Man, it ran real fugly on 87, but smoothed all out after it was gone. I have gotten 94 octane and there's no difference between it and 91 that I can detect, including mileage. So, it is 91 when I can get it and 92 when I can't. The XLCH likes 89 or higher...
Old Dec 5, 2011 | 01:51 PM
  #39
Sharkman73's Avatar
Sharkman73
I run Marathon 93 in my Sporty. Around here, there is 87, 89 & 93....91 doesn't exist locally. I've never ran anything else.
The Marathon refinery is 7 miles from my house & the ethanol blended in is made 3 miles from my house and is blended at the terminal by the refineryis right there. The Marathon gas station is in the same town, so I know the fuel (both the gas and ethanol) is fresh and hasn't been sitting in a storage tank or rail car for weeks.
Unless the station is an actual BP or Sunoco, etc., every mom & pop gas station around here including Casey's, Hucks, Thornton's etc. is Marathon gas from the local refinery with 10 ethanol from the ethanol plant in my town.
Old Dec 5, 2011 | 01:58 PM
  #40
aklim156581's Avatar
aklim156581
Originally Posted by streetfighter06
Mine is not EFI. I run 87. NO DIFFERENCE. Gas and vehicle makers are like the government. Corrupt. I bet Corvettes can run fine off 87, but are specified to run at 91 or 93 because GM got a paycheck from Shell, BP, Chevron, etc to specify false propaganda.
I'll bet they don't get a check from a gas company. How did you determine it runs fine on 87?
