Help! Sportster 48 PCV map??
Old Jun 28, 2011 | 09:34 PM
rconnetta's Avatar
rconnetta
Stage II
Angry Help! Sportster 48 PCV map??
Just bought a 2011 Sportster Forty-Eight. I added the Vance&Hines short shots with the Screamin' Eagle heavy breather filter.
Does anyone have this setup and a map for the Power Commander V that they would like to share?
I used the map from the website but I'm getting tons of popping when I let off the throttle.... so annoying!
Old Jun 28, 2011 | 11:15 PM
Aaron48's Avatar
Aaron48
Let the bike get hot....like 25 miles and see if still does it.
Old Jun 28, 2011 | 11:21 PM
Btechpat's Avatar
Btechpat
PM me your email and I can send you what I have in my nightster. I had a heck of a time with that same set up and finally just put auto tune on it and refined the map from fuel moto.
Old Jun 29, 2011 | 12:52 PM
rconnetta's Avatar
rconnetta
Stage II
@Aaron48: I drove it 40 plus miles for two hours and it popped the entire time.
@Btechpat: email is rconnetta@yahoo.com: I really appreciate any help you can give!
Old Jun 29, 2011 | 01:32 PM
Blaven48's Avatar
Blaven48
With any type of drag pipe like the short shots your not going to get rid of the popping unless you get a dyno tyne and even then its still going to be there from the shortness of the pipes.
Old Jun 29, 2011 | 01:43 PM
Cpitch's Avatar
Cpitch
the popping will never go away....its more prevalent when cold.
get your self some x14ied's. everyone else is catching on to them real quick. no need for a tune or tuner or remap.
www.nightrider.com
Old Jun 29, 2011 | 01:55 PM
Btechpat's Avatar
Btechpat
Sent you an Email with my map. I have to agree with Blavin's comments and in the end I wish I would have just had a competent shop do a full dyno tune and build a custom map for the bike. One thing that I have found is that when I originally added the Auto Tune I was living in the High Desert of Southern California and have since moved to central Texas, and there were some changes in the MAP between the 2 locations so your results may vary. Double check that you have no exhaust leaks and give it a try. Let me know how it works out.
Scott
Old Jun 29, 2011 | 02:52 PM
ogh11756's Avatar
ogh11756
www.nightrider.com
Worked for me when i put rush slipon mufflers on mine.
You will not eliminate the decel pop but reduce it.
tuners & remapping is cash for the toilet.
Old Aug 22, 2011 | 08:26 PM
JohnnyNorCal's Avatar
JohnnyNorCal
6th Gear
I have the exact same setup with the same problem. I'm looking to see if someone has found a PCV map setup that works better than their closest pre map setup which is for High Flow intake, not a heavy breather intake.
I don't mind the popping that much really but It makes me nervous thinking it might hurt the bike although I have heard it both might and might not, lol.
Old May 10, 2012 | 11:21 PM
Mastermason11's Avatar
Mastermason11
Stage III
I'm on the same boat with the same setup. Any map for the 48 with shortshots and SE heavy breather would be appreciated.
