Ex-Changing Fluids
Old Jul 3, 2011 | 04:52 AM
DavidStiebel's Avatar
DavidStiebel
Question Ex-Changing Fluids
According to the Harley Manual;
when changing gear fluid on sportsters you are to install 1 quart of 90 weight gear oil, yet when you look at the detail (page 1-25 diag 1-27) it shows a level line around the bottom of the clutch basket, which when done according to the book (bike is level, no on jiffy stand) is around 1.4 Qt. I have also read using less than 1 qt is done.
With the above in mind; I have read that hard shifting into gear (including difficult neutral) is due to 1 of 2 possibilities, either too much fluid or tight primary chain.
Question is how much gear fluid is correct?
and is setting a loose primary chain better?
Your thoughts,
Dave
Old Jul 3, 2011 | 04:57 AM
Crex39's Avatar
Crex39
I keep the chain with about 5/8 to 7/8 play in it. I used 1 qt. Harley Formula + in the primary, it seemed to find neutral a lot easier after that.
Old Jul 3, 2011 | 12:02 PM
WRAITH's Avatar
WRAITH
The correct amount of fluid is 1 qt or 946ml.
Old Jul 3, 2011 | 12:09 PM
kountry's Avatar
kountry
One quart here to
Brickchick
Jul 24, 2017 04:23 PM
tarheelrdr
Sep 25, 2008 08:49 AM
06STRD
Exhaust System Topics
Mar 16, 2008 09:00 PM
HERITAGEBOY
Mar 18, 2007 05:03 PM
daimlerlimo
Feb 10, 2007 10:03 AM
