Shock/lowering question
Old Jul 18, 2011 | 08:10 PM
Bagger Jim's Avatar
Bagger Jim
Default Shock/lowering question
Was looking to lower the rear a bit and saw lowering brackets on Ebay pretty cheap, but then was thinking of a set of Progressive shocks instead. The shocks I have now (stock) are 11.5" center to center, and I've heard putting 11" shocks will drop it more than 1/2". Can anyone tell me how much drop a 1/2" in shock length will equate to?
Old Jul 19, 2011 | 12:58 PM
mjolnir's Avatar
mjolnir
It's a triangle, so putting on a 0.5" shorter shock will actually get you LESS than a 0.5" drop. But IIRC from reading around on here, what's referred to as an 11" shock is actually sometimes slightly longer, so if you go out looking for 11" shocks, you might wind up with exactly the same thing.
How much lower do you want to go? I'd be worried about starting to rub things inside the fender.
Old Jul 19, 2011 | 06:43 PM
Bagger Jim's Avatar
Bagger Jim
Well, what I thought was since the axle is behind the shock in relation to the pivot point, 1/2 inch of shock length would be more at the axle. I just want to drop the rear about an inch or so. Shouldn't rub the fender at that height. (fingers crossed)
Old Jul 19, 2011 | 07:39 PM
HERE's Avatar
HERE
Ive got one of the cheap adjustable lowering blocks from Ebay, I believe it was less than $40 shipped. Don't be put off by its low price, its actually really well made. Good product and I wouldnt hesitate to buy another.
Old Jul 20, 2011 | 03:42 AM
Bagger Jim's Avatar
Bagger Jim
Thanks YOURADHERE! I was looking at those and couldn't figure out how they worked on a bike cause there are no pics of them installed. Yours looks real nice. I think I'll give it a try, and since most are adjustable for height, I have some options there.
Old Jul 20, 2011 | 05:07 AM
Voony's Avatar
Voony
YOURADHERE,
How long did you try to get the air shocks with the lowering blocks? I was wondering how efficient it would be to have air shocks and lower the bike to, let's say, 10"?
paullavery
Feb 2, 2012 01:23 AM
Cygnus x-1
EVO
Sep 30, 2011 03:19 AM
eviltwin415
Apr 9, 2011 02:09 AM
sniper77
Dec 14, 2008 12:18 PM
Lorance66
Nov 24, 2008 03:55 AM
