Play in shifter
Old Jul 26, 2011 | 01:40 PM
namato1's Avatar
namato1
5th Gear
heybaylor, Thanks. I was hoping it was something along those lines. So I should see it no problem once I pull the primary cover? Never had that off before, any other things I need to look out for? I assume I will have to change the gasket as well for the cover.
Old Jul 26, 2011 | 03:12 PM
HOTLAP's Avatar
HOTLAP
Be very carefull removing the screws on the primary, lots of people strip them.
Try tapping on them with a punch first then use a good quality tool for removal, be sure to use a new gasket and locktite on the screws when you put it back together.
Old Jul 27, 2011 | 04:55 PM
namato1's Avatar
namato1
5th Gear
Got the primary off and found part of a spring in there (see picture) The rest of the spring is on the base of the shifter shaft and I have no idea how to get it off. Any suggestions?
Old Jul 27, 2011 | 08:09 PM
HOTLAP's Avatar
HOTLAP
You really have to get a repair manual to take it from here...or take it to a shop.
Old Jul 28, 2011 | 07:58 AM
3skulls's Avatar
3skulls
Get the manual for sure.
After we got everything stripped down, my buddy that owns a shop took over. The shifter shaft is held on by those springs clamping down and holding it in place.
He had to loosen the clutch pack just a bit to get enough room to pull the shifter shaft out.
If you know what you are doing like my buddy, it takes about 1.5 - 2 hours.
Get all new gaskets, fluids and if you need a whole new shifter it cost about $75
PFR-Captain
Jun 5, 2014 02:27 PM
TheDukester
Aug 27, 2012 07:22 PM
albngore
Jan 10, 2012 08:44 PM
evil_monster
Mar 4, 2009 08:53 PM
JacktheBagger
Oct 2, 2008 09:21 PM
