I can only afford to do one or the other, so which is the best bang for buck. Cam swap or head work. I have a 2006 883-1200 conversion, SE reverse dome piston, mikuni carb. daytoba ignition, arlen ness big sucker, V&H short shot exhaust.
Yes, I am aware it is ideal to do both at same time, soooo unless some one on forum is sending cash with opinion to do both at same time, I would like actual responses of individuals who have maybe done just the headwork with out replacing cams. When cams are done I will go with SE .497 or Andrews N4, same cam I believe, Thanks
I've done only head work. Port and polish. I picked up 6% airflow over the stock heads with no port and polish. yes you'll more than likely have to retune. But it's not like you have a EFI bike. A swap of the jets and your set. I'm very pleased with just my head work More airflow in and out = more power. do what you can afford it's your scooter
That 6% was on a flowjet also. we flowed the heads before and after
When I did the conversion , I opt. for the cams for now an not the head work,,,,I did use the n4 cams,,,,no regrets either,,,I have thought about doing the heads this winter but it pulls to good to go back into at this time,,,this is my oppion if it help'd you any,,,,
Thanks for the replies, i want to do one or the other this winter and the other next year. I know I will be duplicating some work, but it is easier to part with smaller amounts here and there than 1 large amount of cash. I was really just wanting to know which will yield the most gains of the two, cams(n4) or stage 2 headwork.
