Losing Battle
Old Aug 7, 2011 | 01:52 PM
JaxDefenders2009's Avatar
JaxDefenders2009
Stage I
Default Losing Battle
I have a 2007 Sportster XL 1200 Custom and it all started with the battery dieing all the time, so I changed out the Voltage Regulator and then replaced the battery and still after riding for a day, the next morning the bike is dead again so I took it to the harley shop and they changed out my stater and re chargers the battery and everything else, got the bike home the next day and took it off the trailer it wouldnt start, so I went and got a new battery and was able to ride it for one day and the next morning I had no power. does anyone else know where I can go from here?
Old Aug 7, 2011 | 02:22 PM
ranger50's Avatar
ranger50
Trade it in. Electrical problems can be a real pain in the ***.
Old Aug 7, 2011 | 03:29 PM
wilburz's Avatar
wilburz
i would guess you have corrosion issue with your relays and fuse blok. clean all fuses and replace or clean the 2 relays and then repack with dialetic grease and you should be good to go. 07's have a water intrusion issue in the fuse block. do a search and you will see lots of posts on this. your relay is bad and is causing something to cycle while your bike sits. I cant remember the name of the parts but you should be able to hear a faint whirring noise every 10 or 20 seconds while your bike is sitting without running. very faint.
WRAITH's Avatar
WRAITH
Do you know how to use a multi-meter?
Old Aug 7, 2011 | 03:30 PM
mikeallenbrown's Avatar
mikeallenbrown
You have a short somewhere that's draining the battery .... You could try pulling fuses and then replace them one by one to narrow down which circuit has the problem. Do you have a volt meter and a service manual? ...hows your troubleshooting skills?
Stephmaks
Electrical/Lighting/Alarm
May 16, 2016 02:11 PM
1993mooglide
Sep 3, 2009 01:49 PM
firestar99
Jul 16, 2007 05:27 PM
dygulski
Oct 15, 2006 02:40 PM
sails
Jun 4, 2005 08:34 PM
