electrical failure
Old Jul 16, 2007 | 07:21 AM
firestar99's Avatar
firestar99
Default electrical failure
The other day I was riding and my speedo which is a led read out type check engine came on. All of a sudden the bike started to spit and sputter and the bike shut down. once off the road the bike was dead. The battery would only click. I had my wife come with the trailer and we brought her home. I hooked up my charger and the battery was truly dead only showing 7 volts on the meter. After letting it trickle charge for two days I brought the batter to the harley shop and they tested the battery and the battery load tested perfect and they said the battery was in good condition. I brought the bike to them and they tested the regulator and stator and so far have not found anything wrong. Any ideas I am worried that the bike will do it again. I hate being left on the road. I have a 2005 roadking Thanks Terry
Old Jul 16, 2007 | 05:00 PM
japel's Avatar
japel
Default RE: electrical failure
I've been having major problems with my electrical system on my bike. Specially the starter. I have been getting a nasty chattering sound whenever I try to start the bike. I still haven't fixed it, but the solutions I have tried is a new battery, new selenoid, new relay. Also try changing the relay, worst case you might have to start changing wires. Good luck to you.
Old Jul 16, 2007 | 05:08 PM
zukeeper's Avatar
zukeeper
only thing I know of that can kill a battery like that is a wire grounding out. It may have to warm up before making ground....but thats where I would start
Old Jul 16, 2007 | 05:27 PM
Panhead_1_9_4_8's Avatar
Panhead_1_9_4_8
Sounds like you had a loose battery cable. Pretty common occurance.
RoadKingAnni562
Electrical/Lighting/Alarm
Apr 25, 2018 02:31 PM
agove
Mar 6, 2015 09:36 AM
harleyfiremedic
Nov 23, 2012 11:23 AM
frang413
Jul 14, 2009 12:44 PM
sails
Jun 4, 2005 08:34 PM
