POSSIBLE Voltage Problem After Installing Crash Bar Lights
Old Aug 10, 2011 | 09:55 PM
discodave's Avatar
discodave
Default POSSIBLE Voltage Problem After Installing Crash Bar Lights
I had my Kuryakyn (spelling?) crash bar bullet style lights installed today for added light on the road when riding at night. Lights look awesome!
After getting back on the bike after picking it up from the shop after the install, my Dakota Digital gauge is reading "low voltage". My initial thought was that during the install the guys had the lights on for a while during the install for aiming, etc., so maybe I need to ride her for a while to get the charge back up.
Do you think that's all I need to do, or do you think it's draining too much? It's wired into the headlight wiring. The guys at the shop said it shouldn't be drawing too much extra.
Thoughts?
Much appreciated!
Here's a pic of the lights I had installed:
Old Aug 10, 2011 | 10:41 PM
mikeallenbrown's Avatar
mikeallenbrown
Whats the voltage at the battery with the lights on (while bike is running)? ....you have a meter to measure this, right?
Old Aug 10, 2011 | 10:42 PM
mikeallenbrown
While the bike is running the battery is being charged ...should measure 14volts. Does the low voltage disappear with the lights off?
Old Aug 10, 2011 | 11:22 PM
discodave's Avatar
discodave
I have no way to test it right now. I loaned my voltage meter to a buddy of mine. When I'm riding the "low voltage" warning goes away. When I'm idling it reappears. Make any sense?
Old Aug 11, 2011 | 08:44 AM
mikeallenbrown
More or less ....at idle the stator doesn't put out as much and the voltage will drop some. These must be halogen lights? ....they pull a lot of current, as opposed to the LED type. But ya, you're going to need a meter to investigate further.
Old Aug 11, 2011 | 09:35 AM
cHarley's Avatar
cHarley
The charging system on pre 2007 Sporties doesn't have many amps to spare. In it's stock, lights on configuration, you have about 8 extra amps to work with. At idle (1000 rpm), the single phase stator is lucky to keep up with the stock electrical load, but usually falls a bit short, leaving the battery in a discharging state when the RPM's are low.
You might try cranking up your idle RPM a bit.
Old Aug 13, 2011 | 08:00 PM
discodave's Avatar
discodave
Hey, thanks for the info guys. I went for a longer ride last night and it seems to be charged just fine now. The low voltage light warning was on initially but after riding for about an hour it went away. I'm betting my battery got a little drained while they were installing the lights since the bike wasn't on.
bustert
Electrical/Lighting/Alarm
Aug 13, 2018 09:10 AM
cr1340
Sep 20, 2011 08:19 PM
BungoBill
EVO
Aug 20, 2011 12:37 PM
Andjh123
Nov 7, 2009 09:44 PM
rhbuilds
Jun 19, 2008 07:20 AM
