clutch problem?
Old Aug 22, 2011 | 04:28 PM
hdmatt29's Avatar
hdmatt29
Default clutch problem?
i been riding my bike and coming up to 10k miles and i noticed in my 2009 nightster i can sit at light and let clutch out in first gear and clutch dosent grab untill lever is almost let go. is that clutch adjustment or clutch itself worn out? clutch does not slip in any gear
Old Aug 22, 2011 | 04:31 PM
mikeallenbrown's Avatar
mikeallenbrown
Perform the full clutch adjustment per the service manual....will take you about 10 minutes tops
Old Aug 22, 2011 | 04:46 PM
parabellum_9x19's Avatar
parabellum_9x19
+1, if your clutch is grabbing that far out on the travel of the lever, you are close to doing damage to your bike (once it gets bad enough that it never fully lets out, shifting can damage your trans).
The rule I have followed with all of my bikes is that I want the engagement to happen almost exactly in the middle of the travel of the movement of the clutch handle.
https://www.hdforums.com/forum/sport...nce-guide.html
How much slack is in the cable right now?
Old Aug 22, 2011 | 04:50 PM
STRGLD95's Avatar
STRGLD95
6th Gear
My 06 street glide clutch has been that way ever since I got it 2 years ago, put on 7,000 miles, no issues yet, will not slip in any gear either.
Old Aug 22, 2011 | 05:35 PM
hdmatt29's Avatar
hdmatt29
when bike is off not much slack in cable maybe 1/4 inch at most
Old Aug 22, 2011 | 05:45 PM
hdmatt29's Avatar
hdmatt29
i puttin new bars on my bike in week or less should i wait or do adj now and see how it goes?
Old Aug 22, 2011 | 06:31 PM
sioux565's Avatar
sioux565
Do it now. It takes maybe 10 or 20 minutes to go. Just sit the bike up straight so tranny fluid doesn't leak out the derby cover.
sioux565's Avatar
sioux565
Also, use T27 Torx for the derby cover bolts. Use a T25 and you will strip your bolts eventually. I speak from experience.
Old Aug 22, 2011 | 06:42 PM
heybaylor's Avatar
heybaylor
just make sure you have a least a "nickle width of free-play"at the lever
check it with clutch hot.
if it is ok , your good to go ,..
btw there is no way a clutch does damage to tranny, only the rider can..
Old Aug 22, 2011 | 07:34 PM
hdmatt29's Avatar
hdmatt29
ok thank u for the fast responses
