clutch problem?
Old Aug 22, 2011 | 09:46 PM
parabellum_9x19's Avatar
parabellum_9x19
Originally Posted by heybaylor
just make sure you have a least a "nickle width of free-play"at the lever
check it with clutch hot.
if it is ok , your good to go ,..
btw there is no way a clutch does damage to tranny, only the rider can..
What I meant was that if his clutch is not fully disengaging, and he stomps the shifter into the next gear, that can definitely put way more shock on the gears than normal, which could in turn damage the transmission.
Old Aug 23, 2011 | 04:27 PM
SportyPig's Avatar
SportyPig
The clutch cable needs adjusting. That is not a symptom of a clutch out of adjustment
Old Aug 23, 2011 | 06:25 PM
Warpfield's Avatar
Warpfield
About three weeks ago I started having issues with my clutch. At a stop light it would grab, even when fully squeezed. In the upper gears when I got on it, the clutch would slip. I tried adjusting the clutch and cable but the problem persisted. I ended up taking it in to the dealer and they said that the clutch spring had broken and damage some of the clutch plates. Needless to say, I ended up with a whole new clutch pack. It was still under warrantee thank God.
Old Aug 23, 2011 | 09:05 PM
John_K's Avatar
John_K
This is unlikely the OP's problem, but just the same... it's a good idea to get rid of the stupid 'spring plate' and put in an extra clutch plate and couple of steels to avoid this issue. The spring plate is not only useless, it is the weakest link in the stock clutch system and can cause damage when it lets go.
wdb1264
Jan 1, 2015 10:23 AM
bigredwing
Sep 1, 2011 11:00 AM
JR-Boston
Mar 24, 2010 12:26 AM
SportyPig
Sep 26, 2007 09:09 PM
wolf1477
Ironhead
Jan 16, 2007 04:23 AM
