Primary Oil?????
Old Aug 24, 2011 | 06:57 AM
sgw1064's Avatar
sgw1064
Default Primary Oil?????
I changed primary with syn 20/50 in my 09 883. Using 75/90 instead will quiet shifting but will this cause clutch issues? Anyone try the heavier lube?
Old Aug 24, 2011 | 07:07 AM
xFreebirdx's Avatar
xFreebirdx
75/90 is the best to use......
Old Aug 24, 2011 | 07:10 AM
TORQUEY's Avatar
TORQUEY
...and drain that Syn out when you can. Use Amzoil or one of the superior lubricants out there.
Old Aug 24, 2011 | 07:12 AM
b0fh's Avatar
b0fh
I am using straight gear 90 GL4 for thousands of miles - works much better than motor oil but clutch sticks a bit on cold starts. Opened the clutch recently and it looks brand new, even the spring plate I removed to put 3 discs back in its place.
Old Aug 24, 2011 | 07:19 AM
cHarley's Avatar
cHarley
The MoCo's preferred recommendation for primary/tranny oil is their Formula+ which is an ~85w Gear Oil. So yes, a 75-90 syn Gear Oil is an excellent choice. I've run Mobil-1 75-90 syn Gear Oil for over 75,000 miles in mine.
Old Aug 24, 2011 | 07:21 AM
Booey424's Avatar
Booey424
I use Mobil 1 75/90 syn gear oil. Shifts just fine. I also use Mobil 1 V-Twin 20/50 motor oil in the oil tank. It also works well
Old Aug 24, 2011 | 07:45 AM
1200Cdriver's Avatar
1200Cdriver
After having Syn 3 at the 1,000 mile check up, then Amsoil 20w50 at 5,000, I settled on Formula+ at 10,000 and it "seems" to be the quietest and smoothest. 25w60 RevTech tamed some of my engine noise.
Gilmb
Oil Archive (no new posts)
Feb 11, 2015 08:40 PM
KCFLHRC
Jul 21, 2010 01:30 PM
ScReaMnEagLE22
Feb 19, 2010 02:13 PM
bikecop40
Nov 4, 2007 10:15 PM
Chief101
Nov 29, 2006 04:04 PM
