Not as nice as Kingston... haven't been out that way in ages. There are a few nice routes, best one is a 4 hour run along Detroit river, down to Lake Erie, then cut across to Lake StClair and back to Windsor, basically a perimeter run of Essex county. A few mild twisties here and there, plenty of decent food stops and lots of riders to meet along the way.
Sounds decent. Kingston has some good places to ride but I don't typically meet a lot of riders. I ride alone, I think it's because I'm young and people probably just think I'm a squid. I think once I started really tearing into the bike people seem more willing to take a second look. I've had a bunch of older riders compliment the bike lately.
I've only met a few snobby riders, but I think most are just as self-conscious as me, and when you approach them they usually warm up to a friendly chat. The majority of my riding buddies live either in Michigan, London, or are working the wrong shift to ride with me, so I seldom get to ride with friends. I'm okay riding alone, but when you get into mechanical trouble, it sure is good to have those friends nearby... saved my a$$ a couple of times!
I used this tool for getting oil level correct and run Belray 7w.
The tool is Progressive FOL-1
That'd be a handy tool, particularly if you need to pull some oil out. I used a flashlight and 12 inch flexible steel rule, it's a little more work and not as accurate, but buying the springs was over budget for me to begin with!
Thanks all!! I don't think it will be much of a problem for me. I have heard the Progressive springs make a real difference in the ride. I really don't know if the previous owner ever changed the fork oil (doubtful) but I will when changing the springs. Think I'm going with the 412's for the rear too. Right now, my bike rides like a shopping cart which I'm sure in part is from the rear lowering kit. It will be coming off when I order shorter rear shocks.
JC, I installed 13.5" Progressive 440 standards when I did my forks, I also installed LAChoppers 1" lowering blocks. The lowering blocks made the very compliant 440s feel harsh on small bumps so I removed them. The 13.5 inchers didn't raise the bike as much as I had anticipated, then someone on here said that since the shocks are angled about 45 degrees they only raise the bike about 1/2 the additional length. I think the lowering blocks make the ride harsh because they place the shock mount behind the axel and change the leverage between the shock and swingarm. I like tha way it sits, I hate the slammed look because it makes a bike look broken like a sway backed 18 wheeler trailer.
