Removing muffler
Old Sep 14, 2011 | 03:17 AM
trmac's Avatar
trmac
Big Kahuna HDF Member
I've used silicone spray and rock it side to side instead of the twist/pull - seems to loosen up and come off a whole lot quicker that way.
Old Sep 14, 2011 | 04:29 AM
MADDOG187's Avatar
MADDOG187
i use a pipe with a rubber grip on the end , but a broom stick with some padding on should do the trick , then push it down the header end and use the weight of the muffler like a slide hammer , tapping the stick on the floor ,
use plusgas or a deep penetrating oil first , be gentle and use lots of small taps rather than big ones and you shouldn't damage anything ,
it always works for me , even on really tight baffles ,
Old Sep 14, 2011 | 05:21 AM
moose thecat's Avatar
moose thecat
From: west central michigan 2 miles from the big pond
Before u put the muffler back on coat the pipe & muffler with neversease &the next time u remove them they will comeoff alot easer.
Old Sep 14, 2011 | 10:36 AM
Sharkman73's Avatar
Sharkman73
Originally Posted by parabellum_9x19
+1
Go get a can of Kroil, that stuff is worth its weight in gold.
I had the same issue and used the Aero-Kroil and let it soak for an hour or so...helped a bunch but still was a SOB to get the front one off.
pubofc1
May 25, 2017 08:09 PM
bluharley
EVO
24
Mar 5, 2014 10:43 AM
gilmour68
Feb 20, 2009 08:44 PM
FatBAGstr'd
Jan 24, 2009 10:54 AM
classicjade01
Dec 20, 2006 11:56 PM
