Lugging
Old Mar 24, 2023 | 03:06 PM
svespie's Avatar
svespie
Stage I
Originally Posted by parabellum_9x19
Assuming flat ground and standard gearing/tire sizes, I would NEVER recommend shifting below:
1-2 - 25mph
2-3 - 35mph
3-4 - 45mph
4-5 - 60mph
If you stick to that, you should always be shifting around 3400rpm, no lugging for sure.
If you are chugging the engine in 5th at 45mph, you are going to mess up your bike.
Sportys, more than any other type of HD, like to run high rpms.
Please refer to the following:
New to riding and experiencing the same thing. This post was very helpful for me. Thank you!
Old Apr 6, 2023 | 10:26 AM
Carby Hamcan's Avatar
Carby Hamcan
1-2 - 25mph
2-3 - 35mph
3-4 - 45mph
4-5 - 60mph
I'm on my first Sportster too; a 2003 1200c. My commute is an uninterrupted 45-55 mph on smooth, rolling forest roads. And although the owner's manual says I could do this ride in 5th (says it's okay to shift to 5th at 45mph), there's no way that can be good for the motor. The range offered here by parabellum_9x19 is more in line with what I'm finding, The bike is a lot happier in 4th gear riding between 45 and 60 mph. I'm a little disappointed along with the OP as I was really looking forward to that tractor torque sound I hear from the bigger bikes.
Old Apr 22, 2023 | 12:47 PM
sirrom1's Avatar
sirrom1
“Short Shifting” is shifting up at too low an engine RPM, this is also called “Lugging”. How to tell if you are Short Shifting? This is the way I was taught drive.
In second gear or higher gear, hold the throttle in the same position and down shift. The engine will speed up and one of the following things will happen:
  • The bike speed will decrease
  • The bike speed will stay the same
  • The bike speed will increase
Interpreting the above:
Speed Decrease: This is what should happen when you down shift, it means you are in the proper gear for road conditions. You have not Short Shifted.
Speed Stays the Same: This means you are almost okay, but you have Short Shifted, the engine wants to be in this lower gear.
Speed Increase: This is Lugging, and it is bad. If you drive this way all the time you will damage your engine. This also hurts gas mileage as you are using more throttle than necessary.
Ultra_RB
Milwaukee Eight (M8)
47
Mar 30, 2022 08:09 PM
Alexey K
Apr 30, 2019 12:29 AM
shanet1975
Mar 16, 2011 03:19 PM
Captain Chaos
Nov 27, 2010 05:30 AM
hcmiller92
Apr 21, 2009 09:01 PM
