Wattage stat
Old Sep 17, 2011 | 04:30 PM
sbcvulcan's Avatar
sbcvulcan
Default Wattage stat
Does anyone know how much wattage, not amperage, my 06 sportster 1200 low produces please?
Old Sep 17, 2011 | 04:32 PM
wolfman 66's Avatar
wolfman 66
Volts times amps = watts
Old Sep 17, 2011 | 04:37 PM
Gpsjr10's Avatar
Gpsjr10
Curious as to why you need that info...
Old Sep 17, 2011 | 05:09 PM
sbcvulcan's Avatar
sbcvulcan
looking at attching heated garments
Old Sep 17, 2011 | 09:58 PM
Gpsjr10's Avatar
Gpsjr10
The stator is rated at 38 to 50 amps (depending on RPM). That means it is rated at 500 to 600 watts total.
Old Sep 18, 2011 | 06:57 AM
xFreebirdx's Avatar
xFreebirdx
OEM Stators are not rated that high, or even close. Those numbers look like 3 phase stator numbers. But the amps for a 3 phase Sportster Stator run from 17 amps at idle to 38 amps at 2500 rpms......
OEM Stators Max out somewhere around 22 amps....... 12 amps at idle and 20 amps at 2500 rpms.
Old Sep 18, 2011 | 07:39 AM
Gpsjr10's Avatar
Gpsjr10
I guess I was looking at aftermarket ones, but it all depends on the year of the bike, from what I can tell, the newer model years are rated higher than the older ones.
Old Sep 18, 2011 | 08:16 AM
cHarley's Avatar
cHarley
07 and up EFI bikes have 38 amp systems because of the additional load of the injectors and fuel pump.
With the OP's 22 amp system, he's fine for heated gloves and a vest/jacket assuming he hasn't added additional accessories like driving lamps.
Old Sep 19, 2011 | 02:11 PM
SportyPig's Avatar
SportyPig
Yep, what cHarley said. I've been using the heated jacket liner and gloves for 3 winters. They work great. You can't add the heated pants though, that creates a electrical demand than the stator can produce.
If you find the jacket at the Harley dealer, it will have a large booklet that goes into great detail of what you can run one the bike, of each model and year.
QBANHARLEY
Jun 18, 2020 07:49 PM
agove
Mar 10, 2014 09:12 PM
sbcvulcan
Apr 19, 2010 06:18 AM
big swifty
Aug 27, 2007 08:27 PM
