Using Rebar
Old Sep 24, 2011 | 07:37 PM
Aaron48's Avatar
Aaron48
Go with some #5 Bar its got some girth to it. Its 5/8 of an inch...Plenty strong.
Old Sep 25, 2011 | 08:42 PM
cdkyle's Avatar
cdkyle
Rebar comes in different grades also, i.e., #40 and #60 grade with #60 being the better grade of the two.
Size is #3 = 3/8", #4 = 1/2" #5 = 5/8", #6 = 3/4", #7 = 7/8", #8 = 1"
Rebar has fairly good tensile strength for bending etc., but it biggest enemy is water and rust. That is why the highways require the green coating.
Never thought of using rebar on a bike, but it might look cool. It must be powder-coated or painted.
Old Sep 25, 2011 | 08:43 PM
cdkyle's Avatar
cdkyle
Also, cold rolled steel seems to be a MUCH better of quality of steel as opposed to rebar.
Old Sep 25, 2011 | 09:14 PM
SteveO-ll's Avatar
SteveO-ll
If you go with Stainless, use stainless welding rod that is of a compatible grade, as there are several types of rod. I recommend using a TIG welder to do the welding. The nice thing about stainless is all you have to do is polish it when done.
Old Sep 26, 2011 | 05:54 AM
xFreebirdx's Avatar
xFreebirdx
If you have ever seen "green" rebar, the green is a epoxy coating and it has a Rockwell hardness of 6060.
Old Sep 26, 2011 | 07:32 AM
bobscogin's Avatar
bobscogin
Originally Posted by thoner7
Does anyone know if I would be OK with using standard steel rebar?
You'll be OK if you're using it for reinforcing concrete, but not for motorcycle accessories. Rebar is not ordinarily intended to be welded. The American Welding Society (AWS) D 1.4 sets out the practices for welding rebar in the U.S. Without special consideration the only rebar that is ready to weld is W grade (Low-alloy — A706). That said, you're not likely to find that type. Grades 40 and 60 are most common, but aren't readily weldable due to the high carbon content. Rebar isn't inferior in strength to any other steel. Just use it for what it's intended.
Bob
Old Sep 26, 2011 | 08:06 AM
soft 02's Avatar
soft 02
Bob
Yes it is not recomended to be welded when using it in concrete but I have done many small projects with rebar and never ever had any issue. From adding it to the paddles of a scraper to augers that had worn flighting. I even made my sissy bar out of the stuff.
Old Sep 26, 2011 | 09:42 AM
bobscogin's Avatar
bobscogin
Talking
I wonder how it knows whether or not it's in concrete?? lol!! I'm sure there's been lots of welds done on rebar that have held just fine. I just thought that anyone anticpating misusing it should be aware of the risk and limitations.
Bob
rebelraider
Jul 3, 2020 08:28 PM
WoodrowWillson
Jul 19, 2012 08:01 AM
louisianaSVT2001
Nov 18, 2010 01:13 PM
sgtrod91
Apr 13, 2008 04:25 PM
GothMetalGuitarist
Aug 6, 2007 05:12 PM
