Using Rebar
Old Sep 19, 2011 | 04:12 PM
thoner7's Avatar
thoner7
Default Using Rebar
With winter approaching in the north, I have been thinking up some custom mods for my bike, and I want to make them out of rebar. However, I have heard that rebar isnt the best building material outside of its designed use in concrete. Mainly, it can be brittle and break because its all the leftover scrap steel fused together.
I have a cool design for a sissy bar in my head, and I figure that would be fine using standard rebar. But I also was thinking about some custom made handlebars and forward controls.
Does anyone know if I would be OK with using standard steel rebar? If not I could order some Stainless rebar but that can be pricey but according to the below thread(if you read the whole thing) is much better of a material to use(I live about an 1 1/2 from Niagra Falls and am in that area every so often, so getting my ahnds on some SS stuff is no problem).
http://www.harley-davidsonforums.com...andlebars.html
I would also be welding this stuff together - is there anything I need to know about welding Stainless? Thanks to all the much smarter people out there.
Old Sep 19, 2011 | 04:38 PM
Galdog's Avatar
Galdog
Rebar is not brittle. I work on a hot steel rolling mill and we roll rebar. If it was brittle, it wouldn't make it through the mill. We also do bend tests on it after rolling to make sure it isn't brittle. Also, think about it, all the buildings and bridges that have rebar in them, do you want it to be brittle? There are many sizes of rebar from #3 (.375") to #18 (2.257"), if your not sure of what size you want, the internet will tell you the sizes. Used to roll stainless at one of my other mills, higher quality steel, no doubt. If your going to powder coat the steel, regular rebar would be fine. I am not a welder, but I think you'll need special rod to weld the stainless.
Old Sep 19, 2011 | 04:39 PM
soft 02's Avatar
soft 02
I made my 18" sissy bar out of rebar and you would be suprised the amount of compliments I get.
Old Sep 19, 2011 | 05:17 PM
TennesseeMustangPerf's Avatar
When my dad built the garage at my childhood home, he cross stacked the cinder blocks, then filled them with concrete and inserted rebar in each hole. My sister's friend was driving like an idiot and hit the garage wall at the door. The car was banged all to crap (hit it at about thirty!) but other than the splintered wooden frame of the garage door, the garage was undamaged! Did not even crack the blocks, which surprised me.
Rebar can be made into a nice looking piece. I have seen a bobber with a steel rebar sissybar and pegs, looked good. It takes a certain look of the bike to pull it off though.
Old Sep 19, 2011 | 06:08 PM
John Hyatt's Avatar
John Hyatt
If you want to go a little beyond rebar check out www.kingmetals.com They have some twisted steel rod and some other cool stuff in 5/4 ''stock.
JonMon
Old Sep 20, 2011 | 08:04 AM
thoner7's Avatar
thoner7
I was a bit suprised to read on the other forum that so many people thought the rebar was not strong enough, sounds like you may know a bit more than them. You think I would be safe using it for handlebars and maybe foot controls too?
What do you guys think of the added weight in the bars? How noticable you think that will be?
I have been meaning to learn to weld, so why not practice on some rebar. Should be cheap enough.
Old Sep 20, 2011 | 08:21 AM
UFOtestpilot's Avatar
UFOtestpilot
If you can already weld, learning to weld rebar wouldn't be bad, its welding it to dissimilar metals that gets a little different. You wouldn't need to weld it to make pegs, and I don't know that bars would be good as you'd have to do make the grips work and you'd have some HEAVY dangerously handling bars.
A simple way to break down the rebar number system is: #1= 1/8", #5= 5/8", #7= 7/8" etc.
I wouldn't use rebar for any of it, but that's because there are materials that have far superior properties for fabrication uses. If it is the look you want, then I hope you get what you're after with it.
Old Sep 20, 2011 | 02:08 PM
Galdog's Avatar
Galdog
Rebar is stronger than people think. Just make sure you pick the right size to do your fabrication with. We use the scrap rebar for numerous things around the mill, it's strong!
Old Sep 24, 2011 | 07:14 PM
thoner7's Avatar
thoner7
Yea, I have been rethinking making the bars out of it because of the weight.
Anyone know the OD of handlesbars at the grips?
Old Sep 24, 2011 | 07:18 PM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
One inch.
