differences between Carbs
Old Oct 2, 2011 | 09:18 PM
socalsilversxt's Avatar
socalsilversxt
Default differences between Carbs
I need a new carb and have been looking at some CV cars but i see a difference between them. My 883 is a 06
most i have seen are like the one below.
Mine is like this with the extra inlet valve. will the one above fit.
Thanks
BB
Old Oct 2, 2011 | 11:37 PM
John_K's Avatar
John_K
What was that extra inlet for?
Was it connected to anything?
If it is a California spec, maybe an evap canister?
I think it would be illegal if you were to disable that system.
Old Oct 3, 2011 | 03:05 AM
cavalier2000's Avatar
cavalier2000
i have the exact carb on my bike (or simular) it was off a fatboy i believe... either way i was told to just block off the extra port.
here i found the e-mail
the extra fitting that is capped off is a smog pipe so dont sweat that part
looks like the upper fitting is capped with a red cap and that goes to the voes or map sensor.
dont worry about the bottom vent as that is an overflow in case the float sticks.
Old Oct 3, 2011 | 12:08 PM
socalsilversxt
I have a hose on mine connecting to that inlet valve. mine is a California bike. What does that hose connect to on the bike? Can i remove it to put a carb that does not have it on?
Madnss
Exhaust System Topics
20
Jun 5, 2017 11:44 AM
Big Dave
Apr 8, 2017 09:58 AM
Big Money
Evo Era Parts
Feb 26, 2016 11:46 AM
VASportster
May 8, 2011 02:13 PM
PatCalabrese
Dec 8, 2009 09:59 PM
