Front Wheel Bearings
Old Oct 26, 2011 | 02:03 PM
baust55's Avatar
baust55
This spring i bought a 2008 FLHRC with 27,000 miles on it from Dillon Brothers HD in omaha . great dealer . The bike now has a little over 35,000 miles on it.
A cpl weeks ago i was doing a pre-ride safety check ,as i checked my front tire air presure .i saw that what apeared to be the front right wheel bearing seal pushed out onto the spacer. i could see in the race the dry ballbearings . looked like maybe a few were missing .? i put the bike on lift and checked for play and felt non. i packed some grease in and pushed the seal back in .
i then made the drive to Dillions i stopped a few times to check for heat ect .
Dillions advertises no wait drive up service .
when i got to Dillions i explaned the problem and told them i had extended service plan . they said your coverd . and took the bike right back to be worked on . after a half hour they came back and said it would be another hour .
All said and done ...they got it fixed right away and washed the bike to .
it cost me $50 ...the deductable on my extended service plan.
The tech told me he had seen a lot of wheel bearings failing recently.
Old Oct 26, 2011 | 02:17 PM
parabellum_9x19's Avatar
parabellum_9x19
Originally Posted by joebotics
Hey Para... is still the kit you are talking about by any chance?:
http://www.amazon.com/All-*****-Whee.../dp/B0036GGFFE
if not. can you please provide a link if possible to that particular kit you bought?.. thanks!
Yes that is the exact same kit (25-1571).
Old Oct 26, 2011 | 03:50 PM
cHarley's Avatar
cHarley
Originally Posted by emperor wurm
you should repack them everytime you change your tires....thats what I have always have done on all my bikes.
The only Harleys with wheel bearings that need repacking were years 2000 and earlier. All later model Harleys have sealed bearings.
The sealed bearings used between 2000 and 2007 are/were good quality double row bearings. These bearings have no known issues and typically are good for 75,000 to 100,000 miles. I just replaced my original bearings at 76,000 miles, not because they were bad, but I figured better safe now than sorry on the side of the road later.
In 2008, with the introduction of the hollow axle, Harley changed to a single row bearing and subsequently started importing them from China. The single row bearings $uck IMO, and the quality control from China doesn't help.
All-***** manufactures top quality (USA made) replacement bearings, and they are carried by many of the common distributors, like JP Cycles, etc.
Old Oct 26, 2011 | 04:43 PM
joebotics's Avatar
joebotics
Thanks much!!.. now.. I just need to find a source for the fork stem bearings.. :-)
Old Oct 27, 2011 | 09:15 AM
Ergonight's Avatar
Ergonight
Joe, did you try Vulcan Engineering? I don't see a separate listing for the bearings but all of their fork kits come with new bearings. I'm assuming they would sell them separately if you called them. Just a thought.
Old Oct 27, 2011 | 09:46 AM
Gpsjr10's Avatar
Gpsjr10
I found a part number for the All ***** neck bearing kit Part# 49-9583
Old Oct 27, 2011 | 10:07 AM
joebotics's Avatar
joebotics
hey.. nope... not yet.. BTW.. did you get the vulcanworks wide glide kit?... I have been thinking about perhaps getting it for my bike... my old FL front end while it looks good... it is old.. and it is a bit rough... man.. I need a second job.. :-)
Thanks much Gpsjr !!!!
Dumb question.. I know the wheel bearings changed in 2009 t0 25mm ... did the fork stem bearings stay the same?... thanks!..
Old Oct 27, 2011 | 10:45 AM
JohnnyC's Avatar
JohnnyC
Good job of bringing all the details and a good aftermarket replacement. (Yes I realize this is the Sporty Forum)
I have to have a front wheel bearing that is "rough" on the right or left side. When turning, or veering to the left I feel it pulling oddly, a rough feeling but not critical. To the right it feels extremely smooth.
The only reason I have not torn into it is because it hasn't been a priority issue (I've had many of them this year). Also I was under the impression on my '86 that some type of specialized tools, or a specific puller was need to remove the old bearing ... I will be focusing on this now!
Old Oct 27, 2011 | 10:51 AM
Ergonight's Avatar
Ergonight
Grrrr...not yet man. It shipped a week ago and still hasn't arrived. Really pissing me off. I coulda driven over there in a couple of hours and picked it up myself. Damn. I will let you know when I get it!
top0211
2014-2024 Touring Models
17
Aug 13, 2018 05:17 AM
JHL-ShinySideUp
Milwaukee Eight (M8)
31
Jul 27, 2017 03:36 PM
TheFez
Apr 25, 2017 03:11 PM
Northern Glide
Jul 5, 2013 09:01 AM
Professor
Aug 16, 2008 06:48 PM
