Any warning for wheel bearing failures?
Seen scattered posts related to wheel bearing failures on later model touring machines. If you have experienced a failure ........did you notice anything "loosening up", or did they just let go without notice? Thinking I should not yet have problems at 30K (?).
Thanks - Be Safe.
Here is the post when my wheel bearing failed
https://www.hdforums.com/forum/touri...ase-marks.html
2 weekends ago the wife and I were plowing down the GS Parkway doing between 70 - 85 MPH.
Last Friday I was rounding the corner by my house (about 15 - 20 MPH) when my bike let out a huge groan and started grinding. I babied it the last 50 feet to my garage, got off and looked at the front wheel. TOTAL CATASTROPHIC FRONT WHEEL BEARING FAILURE on the right side! HOLY CRAP!! NO WARNING! I had the bike towed in yesterday to the dealer.
I'm having the dealer do tires, valve stems and ALL the wheel bearings (I'm supplying my own with SKF 6205-2RSJ bearings). This bike has been meticulously maintained be the dealer. It had just had its' 10,000 mile service done last fall.
I'll add in that I am an avid reader here and was well aware of other postings about late model wheel bearing failures. 5 days prior to the failure I had washed and detailed the bike. When cleaning I ALWAYS grab and shake stuff, check for loose parts and had INSPECTED THE BEARINGS! There was no warning!
https://www.hdforums.com/forum/touri...f-failure.html
https://www.hdforums.com/forum/touri...g-failure.html
https://www.hdforums.com/forum/touri...-8500-mil.html
https://www.hdforums.com/forum/touri...a-classic.html
Not my picture but from the link above.
It's obvious to me that Harley had a batch of bad bearing or their quality control sucks. Like I said in more than 70k miles I had one go bad and that was around the 10k mark. Thats one to many in my book, I've never had a wheel bearing go bad on any bike I've owned. For the fanboys I didn't ever use a power washer or anything like it on any of my bikes. There is a problem but it seems to be spotty at the most, do I worry about it no, but I'm aware of it and I inspect the area a little closer knowing that it might be a problem.
This is when mine failed
I'm gonna have em checked.
Appreciate the other links. My search didn't pull that many posts up.
Suppose I started an unnecessary thread but much appreciated feedback.
Be safe -
