carb again
Old Nov 9, 2011 | 02:59 PM
Jaystn62's Avatar
Jaystn62
I'm leaning toward that cHarley. I have a rebuild kit ordered but J&P are dragging thier feet getting it to me. I ordered it Oct 25 and after calling yesterday they are saying might be next week before I see it.
Old Nov 9, 2011 | 04:28 PM
SportyPig's Avatar
SportyPig
Seafoam was exactly my thought, I see cHarly is paying more attention this afternoon than I am. haha
I took advantage of the sky clearing after a morning of rain, and temps in the low 70's for a nice bike ride.
Old Nov 9, 2011 | 04:36 PM
Jaystn62's Avatar
Jaystn62
Never tried the seafoam. Exactly what is this? I tried riding earleir but wind was so strong had to lean at about a 15 dgree angle to stay on the road.
Old Nov 9, 2011 | 04:52 PM
cHarley's Avatar
cHarley
Seafoam is designed to clean gum and varnish (the junk stale gas turns into) from your fuel system. It's also a fuel stabilizer which keeps gas from going stale to begin with, like when the bike is not going to be ridden for several months or more.
Old Nov 9, 2011 | 04:56 PM
SportyPig's Avatar
SportyPig
You can find the Seafoam in just about any automotive parts store. In the area with other carb cleaners etc. It is most commonly found in a white can about the size of a 16 oz beer, with a lot of Red writing.
Just follow the directions, or in this case, maybe add a little more than the normal ratio. I use this as part of my routine maintenance. When I change the oil, I run a tank of Seafoam treated gas.
Old Nov 9, 2011 | 05:04 PM
Jaystn62's Avatar
Jaystn62
Thanks guys I'll try this plus going to put in the kit if it ever shows up. Is there any good products to clean the carb with while I have it apart?
Old Nov 9, 2011 | 05:10 PM
SportyPig's Avatar
SportyPig
Try the Seafoam first. It's a cheap and easy treatment. If it doesn't work, you will still have some really good stuff to use in the future.
Why rebuild the carb, if all it needs is a good cleaning???
Old Nov 9, 2011 | 08:33 PM
Jaystn62's Avatar
Jaystn62
Well my thinking is since the guy I bought it from only put 8,500 miles on it maybe things aren't as limber as they should be. And don't have a piture to share but inlet side of carb when I had it off last had quiet a bit of black on bottom of inlet and on cv slide. I'm a patient man and sure I'll get this problem resolved with help. Will try the Seafoam first if I can get some riding time in.
Old Nov 10, 2011 | 09:49 PM
Jaystn62's Avatar
Jaystn62
While I'm thinking of it is there supposed to be a gasket between carb and rear a/c housing? I know there is one between filter and housing but nothing between carb and housing?
Old Nov 10, 2011 | 10:21 PM
Jaystn62's Avatar
Jaystn62
Don't worry about responding to that last post. I found a diagram online of a/c assy and shows a gasket between a/c and carb. Mine is missing and I'm sure it was when I bought bike. Might have something to do with my problem. Don't know but guess I should order one. Thanks for all your patience.
