carb again
Old Nov 8, 2011 | 10:55 PM
Jaystn62's Avatar
Jaystn62
Default carb again
I'm sure the regulars here hate this but I need suggestions. Over last few days I replaced the intake and carb to intake seals on my 06 883c. I had an off idle pop and sometimes stumble. This wasn't everytime I took off. But at times could get irritating. I also put in CV Performce ez adjust enrichment needles. I adjusted according to instructions and I seem to still have same problem. I have also changed plugs and I have had carb back off to check that everything went back together correctly. Any ideas?
Old Nov 9, 2011 | 07:20 AM
JohnnyC's Avatar
JohnnyC
I'd check the engine timing. It's an involved process and might be a dealer task unless you have the equipment to set the timing yourself.
Old Nov 9, 2011 | 07:45 AM
olddude48's Avatar
olddude48
Try going up a size on your low speed jet!
Old Nov 9, 2011 | 08:22 AM
SportyPig's Avatar
SportyPig
Some regulars here welcome these type questions. Soooo much better than the typical post of "How can I cut another 2 inches off my fender".
Try reading and following these articles. They have always worked for me when I had similar carb problems.
http://www.harley-performance.com/ha...arburetor.html
http://www.harley-performance.com/ha...r-jetting.html
Old Nov 9, 2011 | 08:26 AM
rickss69's Avatar
rickss69
I once fought a similar problem only to find in the end it was a faulty petcock.
Old Nov 9, 2011 | 09:53 AM
cHarley's Avatar
cHarley
The ignition timing on an 06 with the stock ICM is not adjustable.
What size jets are you running, and do you have the stock A/C or a Hi-flow (stage 1) A/C?
Old Nov 9, 2011 | 11:48 AM
Jaystn62's Avatar
Jaystn62
My bike is stock with 8,665 miles. The only thing I have done is cut out the internal baffles from the stock mufflers. From what I'm reading online the timing isn't adjustable. And Sporty those are the exact articles I used to get to where I am now.
Old Nov 9, 2011 | 12:20 PM
JohnnyC's Avatar
JohnnyC
Really, no adjustment, even at the ignition sensor? OK
I thought all internal combustion motors required some device / or method to set the ignition timing correctly. Always thought there were variables that needed to be adjusted and set correctly.
Old Nov 9, 2011 | 02:32 PM
Jaystn62's Avatar
Jaystn62
Funny thing is it runs out fine on the road with some rpm. I just can't see a stock bike needing any more jetting than what it has now. I'm no expert though. I know I could be wrong.
Old Nov 9, 2011 | 02:39 PM
cHarley's Avatar
cHarley
That's only about 1500 miles per year, which would make me think you might have a gummed up carb. Have you rebuilt the carb or tried running a couple of tanks of gas with Seafoam in it to see if that helps?
