rear linkage bolt type/size?
Old Nov 29, 2011 | 02:16 PM
Jackal's Avatar
Jackal
No offense, but only thing I've managed to do with those is destroy fastener heads QUICK. I've never had a problem using normal hand tools. Worse case scenario is cut a slot in it and use a BEAST of a screwdriver. I don't think he'll have any issues once he gets a decent T30 in there. There's no reason a T30-T40 should fail under 35 ft.lbs. like every single Lisle ever made.
Old Nov 29, 2011 | 02:33 PM
rickss69's Avatar
rickss69
No offense taken...I have been a mechanic most of my life (near 60 now) and just passing along what works. The problem with Torx is maintaining enough pressure and keeping the bit straight...something the hand impact does well. Overcoming thread lockers will most certainly require more force than the torque specification for any fastener. "Initial shock" is the key here.
Old Nov 29, 2011 | 02:57 PM
Jackal's Avatar
Jackal
I hear ya, and you have twice the experience I do. My uncle gave me one of those and I just never had any luck / got attached to it except ONE time I just remembered. It got the screw out of a dirtbike front master cylinder cover that I had boogered up from not using / having a nice crisp P2 bit.
Old Nov 29, 2011 | 08:06 PM
bmxatv's Avatar
bmxatv
well....got the bastard out but not after losing a few good men in the process. hopefully sears will live up to their motto and replace these freakin torx wrenches. a couple buds came over and helped out and we ended up using a set of needle nose channel locks on the inside of the bolt and the torque side of the t30 t handle at the same time and she budged loose. thanks for the input everyone. in the words of edbassmaster, would ya look at that..lol.
Attached Thumbnails rear linkage bolt type/size?-dscf7411.jpg   rear linkage bolt type/size?-dscf7408.jpg
Old Nov 29, 2011 | 08:38 PM
Jackal's Avatar
Jackal
That sucks man...lol...but at least you got that damn sprocket cover off right? ...and you're all setup to install the mids (unobstructed) that should be there tomorrow.
Old Nov 29, 2011 | 10:09 PM
bmxatv's Avatar
bmxatv
man i took the sprocket cover off and thought it looked like ****. it's goin back on! prolly gonna wrap my pipes too instead of those heat shields, we'll see. be here tomorrow? you f-ing serious? dude you rule! :icon_imnotwor thy:
i'm really going to try and get these shipped out to you tomorrow dude. i'll hit ya up.
Old Nov 30, 2011 | 07:10 AM
Jackal's Avatar
Jackal
Yea, I sent USPS Priority flat-rate (medium) for $10 and change. If not today, tomorrow for sure.
First mod I did was to unshroud the belt. I just like the look and ease of inspection. You could always chop the bitch like Ergo.
Old Nov 30, 2011 | 09:57 AM
bmxatv's Avatar
bmxatv
i'm gonna trim the sprocket cover this winter, round the outside, round the outside. looks cleaner with it on. hope to get yours out tonight as well. thanks again jackal!
cajun1957a
Aug 10, 2018 04:26 AM
Derek Paradise
Jul 4, 2014 07:39 AM
scooter_trash_1
Oct 12, 2010 06:51 AM
HOG_0308
Aug 8, 2010 08:54 PM
cantdecide
Oct 15, 2006 10:59 PM
