Kickstand help
Old Dec 24, 2011 | 10:54 PM
tmors424's Avatar
tmors424
Default Kickstand help
Anyone have any experianced this? The mounting tab that holds the kickstand spring on the frame of my wifes Sportster broke off. It's a welded tab on the lower frame. Any suggestions on how to fix it other than welding? Fustrated!!!
Old Dec 24, 2011 | 11:03 PM
Scuba10jdl's Avatar
Scuba10jdl
You kinda nailed it right on the head there.
Old Dec 25, 2011 | 05:43 AM
xFreebirdx's Avatar
xFreebirdx
+1 Plain and simple....
Old Dec 25, 2011 | 08:29 AM
Cazimere's Avatar
Cazimere
The whole post or just the tip where the spring attaches ?
Old Dec 27, 2011 | 07:05 AM
WVHogRider's Avatar
WVHogRider
I think someone else drilled a hole in the frame, tapped the hole with threads, and put a small bolt/screw in the hole with some Loc-tite.
Old Dec 27, 2011 | 08:11 AM
mreed's Avatar
mreed
Or buy an internally sprung kickstand if you don't want to weld on your frame. You'll probably have to fab an adapter to make it a direct swap.
What's your reservation with welding it fixed? Welding a piece back on is by far the easiest, cheapest & fastest fix.
ryanneal7223
General Topics/Tech Tips
Oct 8, 2015 06:02 AM
VicB
Aug 17, 2012 11:17 AM
62 Basket case
Mar 7, 2010 05:42 PM
crazytrain69
May 8, 2009 09:27 PM
blanco666
Jul 28, 2008 04:40 PM
