5th gear
Old Dec 27, 2011 | 03:38 PM
Ta2edShady's Avatar
Ta2edShady
Default 5th gear
How can I get the bike into 5th gear with the engine out of the bike and no clutch lever installed? Is this easily possible or can I work on the engine without it being in 5th?
Old Dec 28, 2011 | 08:25 AM
Ramboamt's Avatar
Ramboamt
You can use the drive sproket to rotate the transmission, the one from the transmission to the rear wheel. Just rotate the sproket back and forth while upshifting the gear shift. You can also rotate the engine by removing the clutch derby cover and rotating the crank by hand, it will make it easier to turn over the engine if you pull the spark plugs, and going up through the gears. The job of the clutch is to disengage the engine from the transmission when the bike is stopped and during gear changes as it removes the load from the transmission gearing.
So with the engine not running the load is not their so the clutch is not required.
Old Dec 28, 2011 | 08:29 AM
Ta2edShady's Avatar
Ta2edShady
I'll give that a try. I never really thought about the clutch that way but it makes complete sense now that you mention it. I already took the plugs out to inspect them so the pressure should already be relieved. We'll see how this goes.
Old Jan 2, 2012 | 02:29 PM
Ta2edShady's Avatar
Ta2edShady
Worked like a charm. Thanks for the idea!
Old Jan 2, 2012 | 03:43 PM
Gpsjr10's Avatar
Gpsjr10
So, What kind of project are you getting into? Some people may be interested on what you are doing? We want pics too.
Old Jan 2, 2012 | 05:20 PM
camcarvin82's Avatar
camcarvin82
Visegrips
Old Jan 2, 2012 | 05:21 PM
Ta2edShady's Avatar
Ta2edShady
I've completely torn it all down and I'm having a couple things fabbed up. I'll start a thread.
clap
Aug 30, 2013 08:51 PM
dgretz
Aug 24, 2010 09:55 AM
skulznflames
Exhaust System Topics
Jun 4, 2008 10:03 AM
fiveola
Shovelhead
May 18, 2008 01:48 PM
1200c
Aug 22, 2005 12:56 AM
