oil light flashing
Old Jan 5, 2012 | 02:27 PM
cc40110's Avatar
cc40110
Stage III
Default oil light flashing
On my 09 883C sportster my oil light started flashing while riding what is the cause? Please help
Old Jan 5, 2012 | 02:31 PM
IronBoy883's Avatar
IronBoy883
Have you changed your oil recently and were you riding when it can on or did it just stay on when you started it up?
Old Jan 5, 2012 | 02:41 PM
VirgeB's Avatar
VirgeB
Check your oil level to make sure you're not low.
Old Jan 5, 2012 | 03:30 PM
HOTLAP's Avatar
HOTLAP
Four things that I can think of:
1- faulty oil pressure sending unit.
2- oil level too low.
3- major engine problem such as faulty oil pump or worn out motor (not very likley on a 2009)
4- short in electrical system causing light to come on.
If you have lots of oil and have not done anything electrical latley (such as changing bars) than I would change the sending unit, if it's still doing it then you probably need a good tech to test it from there.
Old Jan 5, 2012 | 04:13 PM
cc40110's Avatar
cc40110
Stage III
Default On my 09 883C sportster my oil light started flashing while riding what is the cause?
I have about 2 or 3 thousand miles before next change and oil level is full. I did recently get new bars. The dealer put them on. The light is blinking fast and sometimes not at all and when blinking is fast and faint.
Old Jan 5, 2012 | 04:34 PM
turn8a's Avatar
turn8a
on my 04 my light started to flash all it was is the connection worked it way loose.
Old Jan 5, 2012 | 04:52 PM
HOTLAP's Avatar
HOTLAP
That's it then, they pinched a wire somewhere and it's going to ground lighting the light, it's not a full short or the bulb would be on full bright all the time.
Old Jan 5, 2012 | 05:25 PM
cc40110's Avatar
cc40110
Stage III
Thanks for the help. I'll check the wiring.
Scot7449
Mar 19, 2015 10:49 AM
jacknthebox
Jun 15, 2013 06:46 PM
pjsonnentag
Oil Archive (no new posts)
Oct 12, 2012 09:13 AM
Robert Strohl
May 8, 2012 12:15 PM
MicOnti
Sep 9, 2011 01:56 AM
