Harley did build a belt conversion at one time but it only fit 91-92. I use one of the chains that was the lubricant impregnated into the rollers, it works great.
Darn if I can remember the make but Harley had a chain drive with a drip tube that vented the crankcase and came out over the chain.
Not a bad idea. It made the Bike mark it's area when parked. Ralf nader would never let that go the *** monkey probley killed it along with the Corvair.
JonMon
This is still possible. Run your head breatherbolts into tubes, connect to a "T" and run one line down to the chain. You should put a filter in that line as well. But those breathers also disperse oil. Oil that can either lubricate or be caught in a catch can
