While I've been making minor mods to my bike, it occurred to me to check the age of the tires (should have done that when I bought it). The rear tire was manufactured in 2009, but the front was manufactured in 2006. I don't see any signs of dry rot, but ain't that getting kind of old for a tire? Would you replace a tire that's 6 years old?
How many miles, my front is from March 2007 and has 17,500 miles and still has a few thousand miles left on it. I replaced the rear at 14,650.
My bike has just under 20,000 miles on it, but I bought it in October, so I have no way of knowing how many miles are on the tires. Neither tire needs to be replace due to tread wear. I'm just wondering if the front tire might be unsafe due to its age alone.
So, I have a safety justification for replacing the front Dunlop.
Yep, but if you're going to replace it, I'd recommend an Avon Venom or Metezler 880 over the POS Dunflops. They handle, track and stop much better than the stock tires, especially if you like running the twisties.
aslong as there is no cracks, bulges or chucks missing on the side wall and theres plenty of rubber left on it then it should be fine.
Except that you can't see what's going on inside the tire and what things like 10 years of accumulated moisture are doing on the inside of the tire or wheel.
Front tires are relatively cheap, skin grafts aren't.
